Tractor
 Parts
Yesterday's Tractors
Tractor Manuals
Shop for Parts:
Project Journal
Tractor Town
Show & Pull Guide
Related Sites
The Tractor Shed
TractorLinks.com
Ford N-Series Club
Garden Tractors
Today's Tractors
Classic Trucks
Kountry Life
subscribe
unsubscribe
Content Guide
Picture List - TOC
Ad Archives - TOC
Manuals - TOC
Massey Ferguson 202?
Post new topic    Yesterday's Tractors Forum Index -> Massey Harris & Massey Ferguson
Jcip
PostPosted: Sun Sep 16, 2012 3:36 pm    Post subject: Massey Ferguson 202? Reply to specific post Reply with quote
I am purchasing what a seller advertised as a model 202.I thought it had a 3 cyl perkins Diesel in it, It actually has a 3 cylinder Perkins GAS in it. According to Tractordata, there does not seem to be a 3 cyl gas listed. Anyone know if this is correct? The tractor looks like a normal MF with hi-low range, and 2 stage clutch.
It has a basket case engine right now, am looking for another. What models were the gas perkins in?
samn40
PostPosted: Sun Sep 16, 2012 4:25 pm    Post subject: Re: Massey Ferguson 202? Reply to specific post Reply with quote
Why not fit a diesel back in? If you can find a used diesel perkins then you will find the parts needed for the conversion. Perkins 3cyl gas engines tend to like the fuel whereas the diesel is real easy to fuel.
My thoughts....Sam
Inno
PostPosted: Sun Sep 16, 2012 5:59 pm    Post subject: Re: Massey Ferguson 202? Reply to specific post Reply with quote
The 202 was a 4 cyl Continental gas engine, 6 speed trans (3 fwd. high and low). Some had dual stage clutch some did not.
The 203 was a Perkins diesel, same transmission as the 202.
Far as I know the 202 never had anything other than the 4 cyl Continental.
If you could post some pics or get a serial number etc. that would help.
There was also a 204 and 205, the 204 being same as a 202 but with "instant reverse" and the 205 being like the 203 but with "instant reverse". The instant reverse is a set of pedals operated by your right foot, one on either side of the gas pedal.
Used-to-be-iowa-dave
PostPosted: Fri Sep 21, 2012 7:32 pm    Post subject: Re: Massey Ferguson 202? Reply to specific post Reply with quote
Most 202s came with Continental Z134 gas, but some came with the Perkins gasser. The 203 came with the Perkins diesel. I had a basket case z134 and was able to buy everything from AGCO 8 years ago (shares many parts with the MF35 and others that ran the Z134) for a total rebuild. You"ll probably have more luck finding a Z134 than a perkins gas. I don"t know if the Z134 or Perkins diesel will bolt right up for you.
Garyfen
PostPosted: Thu Oct 11, 2012 9:07 am    Post subject: Re: Massey Ferguson 202? Reply to specific post Reply with quote
I am currently working on a Massey for a neighbor. It is a 202 according to the tag but it IS a diesel. I was trying to find info about it but am running into trouble because I find nothing on the 202 with a diesel engine. Any help would be appreciated.
Inno
PostPosted: Thu Oct 11, 2012 11:25 am    Post subject: Re: Massey Ferguson 202? Reply to specific post Reply with quote
A 202 with a diesel engine would be a 203. See if that helps.
Garyfen
PostPosted: Thu Oct 11, 2012 6:34 pm    Post subject: Re: Massey Ferguson 202? Reply to specific post Reply with quote
Any idea how to tell the year? Will the manuals on ebay tell me how much oil pressure it should have hot? It has 55 psi at full throttle and 25 at idle. After it warms up it is 50 and 20. Thanks for the info.
Inno
PostPosted: Fri Oct 12, 2012 5:31 pm    Post subject: Re: Massey Ferguson 202? Reply to specific post Reply with quote
The serial number would tell you the year but if the serial number tag says it's a 202 and it has a diesel engine then there is no telling just what year it is because some of the parts have been swapped.
202 MF
PostPosted: Fri Oct 12, 2012 5:39 pm    Post subject: Re: Massey Ferguson 202? Reply to specific post Reply with quote
Look on the bottom of the oil pan for the casting date. That will get you close for the engine.
Garyfen
PostPosted: Fri Oct 12, 2012 9:18 pm    Post subject: Re: Massey Ferguson 202? Reply to specific post Reply with quote
Thanks for your help, I will check it out and see what I come up with.
202 MF
PostPosted: Fri Oct 12, 2012 11:06 pm    Post subject: Re: Massey Ferguson 202? Reply to specific post Reply with quote
Nothing wrong with that oil pressure at all.
