Tractor
 Parts
Yesterday's Tractors
Tractor Manuals
Shop for Parts:
Project Journal
Tractor Town
Show & Pull Guide
Related Sites
The Tractor Shed
TractorLinks.com
Ford N-Series Club
Garden Tractors
Today's Tractors
Classic Trucks
Kountry Life
subscribe
unsubscribe
Content Guide
Picture List - TOC
Ad Archives - TOC
Manuals - TOC
PTO cable question
Post new topic    Yesterday's Tractors Forum Index -> Ford
Douglas Miner
PostPosted: Tue Sep 18, 2012 3:32 am    Post subject: PTO cable question Reply to specific post Reply with quote
I have the manual and it looks pretty straight forward removing the the cable if all goes well. My question is if I get the cable out can I run the tractor without the cable in place?
Thanks Doug
Douglas Miner
PostPosted: Tue Sep 18, 2012 3:35 am    Post subject: Re: PTO cable question Reply to specific post Reply with quote
Sorry forgot to add Ford 4000 SOS 4 cylinder gas.
showcrop
PostPosted: Tue Sep 18, 2012 3:48 am    Post subject: Re: PTO cable question Reply to specific post Reply with quote
I don't know what it would hurt. Of course you will want to plug the hole to keep dust out and you will need to remove the cover in order to get the cable back in. I assume that this is a temporary thing but if ends up being long term and the shaft is turning constantly, I would put a cover over the PTO shaft to protect the seal.
Douglas Miner
PostPosted: Tue Sep 18, 2012 5:56 am    Post subject: Re: PTO cable question Reply to specific post Reply with quote
Okay the PTO cable is out no visible damage and it moves freely. Guess the problem is further down.
Tequila
PostPosted: Tue Sep 18, 2012 6:48 am    Post subject: Re: PTO cable question Reply to specific post Reply with quote
Why???
Douglas Miner
PostPosted: Tue Sep 18, 2012 7:30 am    Post subject: Re: PTO cable question Reply to specific post Reply with quote
Why would the PTO cable be unable to move on the tractor but move freely when removed? No rust on the cable just some old black grease.
showcrop
PostPosted: Tue Sep 18, 2012 8:19 am    Post subject: Re: PTO cable question Reply to specific post Reply with quote
Douglas Miner wrote:
(quoted from post at 08:30:56 09/18/12) Why would the PTO cable be unable to move on the tractor but move freely when removed? No rust on the cable just some old black grease.
My PTO cable did not want to move when installed. It was due to a part of the linkage inside being bent, causing interference between the linkage and the interior part of the cable housing. I straightened the bent part, installed and adjusted the cable and it works super nice now.
Sean in PA
PostPosted: Tue Sep 18, 2012 8:31 am    Post subject: Re: PTO cable question Reply to specific post Reply with quote
(quoted from post at 11:30:56 09/18/12) Why would the PTO cable be unable to move on the tractor but move freely when removed? No rust on the cable just some old black grease.
When you install the cable, you actually screw the end of the cable into a piece inside the transmission that moves the PTO control valve, so if the cable moves fine when not installed but doesn't move once it's installed, either it is not adjusted properly or the piece that it screws into isn't moving inside the transmission.
showcrop
PostPosted: Tue Sep 18, 2012 8:43 am    Post subject: Re: PTO cable question Reply to specific post Reply with quote
Sean in PA wrote:
(quoted from post at 09:31:24 09/18/12)
The situation that I had with mine is that the light gauge sheet steel linkage part moved back and forth as it should, and the cable moved nicely in and out when not attached. When assembled, however, the bend pulled the part that the cable threads into enough off center so that it rubbed firmly against the inside of the tube that extends downward from the cover.
Sean in PA
PostPosted: Tue Sep 18, 2012 8:59 am    Post subject: Re: PTO cable question Reply to specific post Reply with quote
showcrop wrote:
(quoted from post at 12:43:22 09/18/12)
The way to test that theory would be to remove the cable, with the handle and housing from the dash, and then remove the conduit from between the back of the dash and the top cover of the tranny, and then put the cable, handle and conduit all back together separate from the rest of the tractor and see if the cable slides in the conduit.
Douglas Miner
PostPosted: Tue Sep 18, 2012 9:07 am    Post subject: Re: PTO cable question Reply to specific post Reply with quote
I made a mistake. I
put the cable back
in and I pushed the
threaded part
inside out of
position I think.
Cable slides nice
but now I have to
pull the cover off.
showcrop
PostPosted: Tue Sep 18, 2012 9:49 am    Post subject: Re: PTO cable question Reply to specific post Reply with quote
(quoted from post at 10:07:16 09/18/12) I made a mistake. I
put the cable back
in and I pushed the
threaded part
inside out of
position I think.
Cable slides nice
but now I have to
pull the cover off.
This is why the manual tells you to thread the bottom section of the trans cable into the PTO to hold the linkage in place until you are redy to put the PTO cable in.a
