AC 180D injector
DEM
PostPosted: Tue Sep 18, 2012 8:41 am    Post subject: AC 180D injector Reply to specific post Reply with quote
I have an AC 180 diesel that has an injector leaking where it is bolted to the head. Can someone give me the part number and tell me if it is available at local autoparts stores? or another source for the part. I am told it is a washer like part, I would need 2 for each injector.
gearheadbill
PostPosted: Wed Sep 19, 2012 3:43 pm    Post subject: Re: AC 180D injector Reply to specific post Reply with quote
Are you sure it is the injector? Don't jump to conclusions. Does it appear to be diesel fuel or oil? A valve cover gasket can leak by the injector and be deceiving. If it is the injector with factory injectors, it is more than likely a copper washer between the upper cap and locking nut, or the washer between the locking nut and injector body. If it is one of these, take care to not alter the injector pressure as you will be where this is done.
DEM
PostPosted: Thu Sep 20, 2012 12:27 pm    Post subject: Re: AC 180D injector Reply to specific post Reply with quote
thanks, I'll take a closer look. It appears to be more of an oil residue that diesel fuel. If it is the injector leaking are those washers readily available at local auto parts stores?
