If it's true - this stinks!
Larry NCKS
PostPosted: Tue Sep 18, 2012 9:03 am    Post subject: If it's true - this stinks! Reply to specific post Reply with quote
I put a new lever type fuel shut off valve on my prior 4000 gasoline about the 1st of April this year. (my records indicate I purchased it on March 13) It is leaking profusely at the stem already. It's bad enough that I'll have to do the whole process over, but my parts man says he doesn't think warranty will replace it.
RodinNS
PostPosted: Tue Sep 18, 2012 1:20 pm    Post subject: Re: If it's true - this stinks! Reply to specific post Reply with quote
Nothing burns me more than paying good money for supposed OEM quality parts and getting china's finest in the box. If that's how it's going to be then china's finest price will work too...
Of course... mabey that corn whiskey is playing a role in this too...
Rod
rustyfarmall
PostPosted: Tue Sep 18, 2012 1:54 pm    Post subject: Re: If it's true - this stinks! Reply to specific post Reply with quote
Tighten the packing nut.
Larry NCKS
PostPosted: Tue Sep 18, 2012 3:17 pm    Post subject: Re: If it's true - this stinks! Reply to specific post Reply with quote
rustyfarmall wrote:
(quoted from post at 16:54:51 09/18/12)
Yeah! You find the packing nut for me and I'll gladly tighten it!
Will Gumbert
PostPosted: Tue Sep 18, 2012 4:33 pm    Post subject: Re: If it's true - this stinks! Reply to specific post Reply with quote
Larry - I had the same experience with the same
type of tap on my 62 4000 a few months ago. In my
case, the thing didn't leak to the outside world -
it just didn't shut all the way off. And it's a
miserable job to re-do!
There's no quality control with these parts today.
I did a rebuild on my TSX 769 carb and found that
the new throttle shaft was machined wrong and held
the throttle plate crooked enough that it jammed
in the bore. - I had to put the old one back in
which worked fine. I guess that's just the way
things are. But I hate to waste time and money!-
Will
PeteTheRookie
PostPosted: Tue Sep 18, 2012 7:54 pm    Post subject: Re: If it's true - this stinks! Reply to specific post Reply with quote
Larry,
Last year when my 4500"s shut off valve started leaking I bought a new NH one off of Messick"s website. When it came and I saw the "quality" of it chose to replace the o ring in the original one instead.
Suppose you just need to change the O ring using a nitrile O ring.
Pete
Larry NCKS
PostPosted: Wed Sep 19, 2012 1:16 am    Post subject: Re: If it's true - this stinks! Reply to specific post Reply with quote
I wonder if I can still find the valve I took off last spring in the trash bucket. That'd likely be my best bet.
Tequila
PostPosted: Wed Sep 19, 2012 7:32 am    Post subject: Re: If it's true - this stinks! Reply to specific post Reply with quote
Larry, I have two. Different tractors that I have installed brass
shut off's I got at the hardware, just had to come up with the
right thread combinations. They were inexpensive and work
flawlessly.
RickB
PostPosted: Wed Sep 19, 2012 10:21 am    Post subject: Re: If it's true - this stinks! Reply to specific post Reply with quote
Larry, is this OEM or aftermarket? If aftermarket, which supplier?
Larry NCKS
PostPosted: Wed Sep 19, 2012 3:11 pm    Post subject: Re: If it's true - this stinks! Reply to specific post Reply with quote
It's OEM.
RickB
PostPosted: Wed Sep 19, 2012 4:09 pm    Post subject: Re: If it's true - this stinks! Reply to specific post Reply with quote
If you do the business I think you do at your local NH dealer, I"d be all over him (or the parts manager). I"d probably eat the cost of the fuel tap if one of my good customers couldn"t get 6 monthss out of it. OEM standard parts warranty is 90 days, I believe. If I weren"t 700 miles from home today, I"d tell you for sure.............
