| Author |
Message |
farmall99 New User
Posted: Tue Sep 18, 2012 10:18 am Post subject: Whats next? |
Alright guys, I have an M Farmall and I'm looking for opinions on what I need to do. Tractor has 4 1/8" pistons, propane head and a modded governor. Dynos in the 70 hp range with 110 hot gas. Looking for more power and was wondering if I need to step up the carb or start looking at cams. Any advice is greatly appreciated. Thanks Zach |
| Back to top |
Dodgeit Long Time User
Posted: Tue Sep 18, 2012 10:27 am Post subject: Re: Whats next? |
Unless your well past 10-1 compression, your using the wrong fuel. Up to 10 -1 I would use 92-93 octane. Below 9-1 I would run regular unleaded. |
| Back to top |
bp4455 Regular
Posted: Tue Sep 18, 2012 11:54 am Post subject: Re: Whats next? |
unless you can turn open rpms thats the limit. its
time to add some cubes |
| Back to top |
farmall99 New User
Posted: Tue Sep 18, 2012 6:35 pm Post subject: Re: Whats next? |
Well our rules around here are pretty lax, so rpm's is not a factor. Had been toying with the idea of running dual h carbs, also have a JD 3020 carb too to play with as well. Just looking for some opinions on what to do on the cheap if possible. |
| Back to top |
jd b puller Tractor Expert
Joined: 07 Jul 2001 Posts: 3165 Location: North Carolina
Posted: Tue Sep 18, 2012 9:27 pm Post subject: Re: Whats next? |
How much cylinder pressure do you have? |
| Back to top |
High Octane Regular
Posted: Wed Sep 19, 2012 6:56 am Post subject: Re: Whats next? |
find a W9 carb, or have your current carb bored out to use a 806 butterfly. a 33 or 35 venturi, if your at 200psi or less the 110 fuel is killing your torque curve. think of 50/50 mix of 87 n E85 for better results. then maybe have a cam built by Bullet. |
| Back to top |
farmall99 New User
Posted: Wed Sep 19, 2012 9:42 am Post subject: Re: Whats next? |
Last time we checked it had around 220 psi cranking compression if I remember right. It also seemed to detonate with 93 gas and when bumped up to 110 all of it went away.
| Back to top |
High Octane Regular
Posted: Wed Sep 19, 2012 11:12 am Post subject: Re: Whats next? |
no doubt shed knock on 93 alone. 110 is a fast, hot burning fuel. you want a cool, slow burning fuel to keep the explosion pushing down, longer, timewise, vs a quick flash fuel. 87 n e85 will run 275psi at 50/50 mix. if you can get it try it n dyno it. its worth the effort. then start leanin the ethanol with more gas till you find the perfect octane n makes the most power. been there, done it. could be worth 10hp or more if you play with this type of fuel. if not, keep runnin 110 n live with what ya got. |
| Back to top |
LarryM Regular
Posted: Wed Sep 19, 2012 5:20 pm Post subject: Re: Whats next? |
I have a 301 carb that my size 36 venturi came out of. I will have to look at that butterfly! Thank You! |
| Back to top |
farmall99 New User
Posted: Wed Sep 19, 2012 6:56 pm Post subject: Re: Whats next? |
Hmm may have to look into the 806 butterfly and bigger venturi |
| Back to top |
YT Home
| Tractor Manuals
| Tractor Parts
| Forum Home
