| Author |
Message |
rd 2N in mo Regular
Posted: Tue Sep 18, 2012 10:54 am Post subject: ford 2000 3cyl. gas |
I am looking for a manual but have not found one yet.
I want to check the hyd level on the tractor but I do not know where to start on this one, no tranny dip stick?
What is the items shown?
A temp gauge?
A hydro pump?
Also shows the serial number
| Back to top |
Sean in PA Tractor Expert
Joined: 27 Feb 2008 Posts: 1716 Location: Southeast PA
Posted: Tue Sep 18, 2012 11:24 am Post subject: Re: ford 2000 3cyl. gas |
First picture, just to the left of the oil filter is the oil pressure sender. The temperature sender is up at the front of the head.
Center of second picture is the hydraulic pump. It is driven off a gear at the rear of the engine.
Looks like the model number is 21012A, which would be an early (1/65-3/68) 2000 with general purpose ag chassis, gas engine, trans driven PTO and a 4 speed transmission. The serial number is C156723, which would be a 1966 serial number. The production code looks to be 6L12B, which would mean that it rolled off the assembly line on November 12, 1966, during the day shift.
The transmission sump is just for the transmission oil. I don't think that the 4 speed had a dipstick. There should be a level check hole with a square headed pipe plug on the right side of the transmission case, just forward of where your right foot is when you're sitting on the tractor. The fill hole for the transmission should be on top of the trans, near the shift lever.
The hydraulic fluid for the 3 point hydraulics that is powered by the pump in your second picture is stored in the rear axle center housing. There should be another level check hole with a square headed pipe plug on the right side of the tractor near where your right heel is when you're sitting on the tractor. The fill hole for the rear end/hydraulics is on top of the rear axle center housing, under where your right butt cheek is when you're sitting on the tractor.
| Back to top |
souNdguy Tractor Guru
Posted: Tue Sep 18, 2012 2:12 pm Post subject: Re: ford 2000 3cyl. gas |
you need to get that oil sender hooked up asap |
| Back to top |
Ultradog MN Tractor Guru
Joined: 22 Apr 2001 Posts: 12570 Location: Twin Cities
Posted: Wed Sep 19, 2012 3:04 am Post subject: Re: ford 2000 3cyl. gas |
Don't unscrew the slotted bolt below the rear oil check plug.
You'll be sorry.
| Back to top |
YT Home
| Tractor Manuals
| Tractor Parts
| Forum Home
