| Author |
Message |
mwilke Regular
Posted: Tue Sep 18, 2012 1:35 pm Post subject: Allis B steering |
I got some good replies to previous post relative to the subject. Thanks! I also got a service manual for "B and C" tractors. If anyone is familiar with this manual, I have a couple of questions. In the first paragraph on page 50 it says "readjust as above" if tight sots are encountered. There is no "above" in this book.
In the fourth paragraph at the end it says "tighten all nuts securely" but there is never any mention to loosen any nuts.
Am I the one that"s "nuts?" Thanks |
| Back to top |
jc okla Guest
Posted: Tue Sep 18, 2012 2:30 pm Post subject: Re: Allis B steering |
back in the 40's we had a B for years. don;t remenber anything to adjust. Broke my nose on the underslung plow lever when I was 10yrs 0ld. glad it wasn't my teeth. |
| Back to top |
Ted in NE-OH Guest
Posted: Tue Sep 18, 2012 2:48 pm Post subject: Re: Allis B steering |
On the back of the steering gearbox and behind the starter there is an adjusting screw and lock nut. It is adjusted as follows. Turn the steering all the way to the end, either left or right. Loosen the lock nut and tighten the screw until it stops, then back it off 1/8 to 1/4 turn and tighten the lock nut while keeping the screw from turning. Note you will have to remove the starter to get to this screw. |
| Back to top |
Ted in NE-OH Guest
Posted: Tue Sep 18, 2012 4:03 pm Post subject: Re: Allis B steering |
Not sure if both Gemmler and Ross steering gear boxes BOTH have the adjustment or not. Can't remember. |
| Back to top |
mwilke Regular
Posted: Tue Sep 18, 2012 5:04 pm Post subject: Re: Allis B steering |
Thanks for the help. I'll Try to see what I can do with your advice. |
| Back to top |
steve(ill) Tractor Expert
Posted: Wed Sep 19, 2012 5:54 pm Post subject: Re: Allis B steering |
one manufactured box has the set screw on the end of the shaft... i think the other has a cam bolt on the cover plate? YOu loosen the 4 nuts on the cover plate and turn the cam bolt slightly to move the gear closer as i remember ? |
| Back to top |
YT Home
| Tractor Manuals
| Tractor Parts
| Forum Home
