| Author |
Message |
andyinct. New User
Posted: Tue Sep 18, 2012 4:19 pm Post subject: Ford 2000 diesel |
Looking at a Ford 2000 diesel - not sure of year. 8 and 2 transmission, loader on it.1600 hours on it. Hour meter may not be working. Not beat up, seems to run good. Anything to watch out for? Any common problems with these? |
| Back to top |
souNdguy Tractor Guru
Posted: Tue Sep 18, 2012 4:36 pm Post subject: Re: Ford 2000 diesel |
2000 diesel 8spd. i'd check to see if it was the live pto model..
power steering?
them 3 cyl were decent.. 2000 was the economy model.
just the usual stuff.
oil pressure? how's it start cold.
take throttle ok?
smoke or slobber excessebely?
leaks
power?
brakes?
hyds?
tires?
tins?
overheat?
pto work?
excessive wear or play in any major component? |
| Back to top |
andyinct. New User
Posted: Tue Sep 18, 2012 4:48 pm Post subject: Re: Ford 2000 diesel |
Has power steering - decent rubber - worst leak seems to be from under tranny - other than that for its age seems fairly straight. Thanks |
| Back to top |
Texasmark1 Tractor Expert
Posted: Wed Sep 19, 2012 5:55 am Post subject: Re: Ford 2000 diesel |
I have a 2000D 4 cyl, simple tranny pto, 4 speed, no PS. Is a '63 model with 3500 hrs prooof meter still working, all original. Some seal leakage between compartments, but nothing worth tearing into. Very reliable and easy to use tractor. The 8/2 would be really slick as would a live PTO, but this works ok. I did repaint it. Bought it about 10 years ago for $3500 delivered.
If yours is a 3 cyl, I have a '65 3000D with the 6/2, live pto and aftermarket hyd outlet. Same with it. I think the hours on it are up around 4500 and no leaks between fluid chambers.
Both tractors are misers with fuel, easy to use and extremely reliable.
Mark |
| Back to top |
Sean in PA Tractor Expert
Joined: 27 Feb 2008 Posts: 1684 Location: Southeast PA
Posted: Wed Sep 19, 2012 6:17 am Post subject: Re: Ford 2000 diesel |
Leak from under tranny could be a couple of things. Could be the drain plug is leaking. Could also be that the rear seal of the engine or the input shaft seal of the transmission, or both, are leaking into the bell housing and dripping out the weep hole, if there is one on that model, or from the bottom seem between the trans and engine. |
| Back to top |
Ultradog MN Tractor Guru
Joined: 22 Apr 2001 Posts: 12437 Location: Twin Cities
Posted: Thu Sep 20, 2012 2:57 am Post subject: Re: Ford 2000 diesel |
Ford used the same weep hole with the cotter pin in it from 1939 all the way through 1983 that I know of. Probably beyond.
I agree the leak is either the rear main seal on the engine and/or the input shaft seal/s to the tranny.
Those are great small tractors. |
| Back to top |
YT Home
| Tractor Manuals
| Tractor Parts
| Forum Home
