Tractor
 Parts
Yesterday's Tractors
Tractor Manuals
Shop for Parts:
Project Journal
Tractor Town
Show & Pull Guide
Related Sites
The Tractor Shed
TractorLinks.com
Ford N-Series Club
Garden Tractors
Today's Tractors
Classic Trucks
Kountry Life
subscribe
unsubscribe
Content Guide
Picture List - TOC
Ad Archives - TOC
Manuals - TOC
JD #52 - What should this part look like?
Post new topic    Yesterday's Tractors Forum Index -> Implement Alley
Badger08
PostPosted: Tue Sep 18, 2012 7:09 pm    Post subject: JD #52 - What should this part look like? Reply to specific post Reply with quote
A friend gave me this plow. I want to use it to do some plowing this fall and get it set up, then work on restoring it this winter.
Trouble is while he had it and was plowing his garden he hit something hard and it unhooked but the rope tied to his seat didn't and he said it broke something. Well I can see where the cast piece is broken. Went and looked at a part's plow, same part I need, but broken too. Looked at a co-worker's two JD #52's and both of them are broke in the same spot too, so what gives? The co-workers plow, one lifts most of the time but not all the time, the other one doesn't lift hardly at all he says.
It's part #D882-A, page 18 in the part's manual.
If anyone has a picture from their plow with this not broken, I would like to see it! Thanks!
Carlyle hoffman
PostPosted: Wed Sep 19, 2012 2:30 am    Post subject: Re: JD #52 - What should this part look like? Reply to specific post Reply with quote
Well guess what ,you have an original like every one else. No not really, many of them got broken by STRONG ARM farmers with little common sense.They thought they were pulling the plow with the trip rope instead of the tractor pulling the plow and because of that many got broken. What a shame, a lot of engineering and a lack of a little common sense. They are around in junk yards if you look a bit. This phone no if you really want one would probably have one to sell you. Good luck. Jesse- 1-570-546-3968
Badger08
PostPosted: Wed Sep 19, 2012 6:18 am    Post subject: Re: JD #52 - What should this part look like? Reply to specific post Reply with quote
Carlyle, thanks for the reply. So pulling the trip rope to hard breaks the casting huh? I will keep that in mind for when I get it fixed. The guy that gave it to me didn't use it much, but unfortunately broke it that last time he used it. I will give that # a call and see what I turn up with....thanks!
dana89
PostPosted: Wed Sep 19, 2012 12:51 pm    Post subject: Re: JD #52 - What should this part look like? Reply to specific post Reply with quote
Hope this helps. Let me know if u need better pics
Badger08
PostPosted: Wed Sep 19, 2012 1:17 pm    Post subject: Re: JD #52 - What should this part look like? Reply to specific post Reply with quote
[quote="dana89"](quoted from post at 21:51:36 09/19/12)
Nope that's great! I can see it, thanks!
Brendon-KS
PostPosted: Wed Sep 19, 2012 5:40 pm    Post subject: Re: JD #52 - What should this part look like? Reply to specific post Reply with quote
Just a little hint: When you do get it fixed up and working, tie the rope through the "eye" in a large hair pin cotter then just clip the pin onto the seat frame or anything else on the tractor. If the plow breaks loose the clip will just pop off and save damaging anything.
Badger08
PostPosted: Wed Sep 19, 2012 6:14 pm    Post subject: Re: JD #52 - What should this part look like? Reply to specific post Reply with quote
Brendon-KS wrote:
(quoted from post at 02:40:53 09/20/12) Just a little hint: When you do get it fixed up and working, tie the rope through the "eye" in a large hair pin cotter then just clip the pin onto the seat frame or anything else on the tractor. If the plow breaks loose the clip will just pop off and save damaging anything.
Brandon, I actually tried the plow out tonight. The previous, previous owner had taken the furrow steel wheel and cut it off and put it on rubber. So I found a steel wheel and put it back on full steel. So then I thought I might as well try it out even though getting dark. I tied a string onto the clutch lever and ran it through the loop on one of the levers and to the tractor and attached it with a piece of wire. And sure enough I made a round and was turning around and the dang thing unhooked and the wire trick worked and it simply just pulled the rope outta the wire. Then just rehooked it and went. Other then that it worked fine. Now just to get it adjusted up right to ride in the furrow and get it leveled a little better and will do some plowing with this plow and my 44H. Thanks everyone!
Post new topic    Yesterday's Tractors Forum Index -> Implement Alley All times are GMT - 8 Hours
