| Author |
Message |
AllisG Regular
Joined: 26 Jun 2011 Posts: 142 Location: north west,Indiana
Posted: Wed Sep 19, 2012 9:51 am Post subject: Replacement head bolts |
Puting new pistons and crank in a ford 8n and I did this at my local high school and somebody stole 1 of the head bolts for the engine. But just 1 probly throw it across our shop at somebody... As for the question Is the bolts used to hold the head on a certain grade or a special bolt or can i go to the local true value and pick up a simple bulk bolt and put in the engine? |
| Back to top |
souNdguy Tractor Guru
Posted: Wed Sep 19, 2012 10:03 am Post subject: Re: Replacement head bolts |
gr8 or 10 is what I would use.. might have had a 5 in it before.. but i'd go 8 min |
| Back to top |
Dean Tractor Guru
Posted: Wed Sep 19, 2012 11:43 am Post subject: Re: Replacement head bolts |
If you want your replacement head bolt to be identical to the OEM bolts, you will need to get an OEM bolt at a salvage yard, as the OEM bolts are not standard.
Dean |
| Back to top |
TheOldHokie Tractor Guru
Joined: 08 Apr 2005 Posts: 5869 Location: Myersville, MD
Posted: Wed Sep 19, 2012 1:11 pm Post subject: Re: Replacement head bolts |
| AllisG wrote: | | (quoted from post at 13:51:18 09/19/12) Puting new pistons and crank in a ford 8n and I did this at my local high school and somebody stole 1 of the head bolts for the engine. But just 1 probly throw it across our shop at somebody... As for the question Is the bolts used to hold the head on a certain grade or a special bolt or can i go to the local true value and pick up a simple bulk bolt and put in the engine? |
The OEM bolts are 7/16-14 x 2-3/8" long. A common 7/16-14 x 2-1/2" grade 8 cap screw will work just fine. Because it is slightly longer make sure it is used in one of the holes that go through into the water jacket.
TOH
| Back to top |
Hobo,NC Tractor Guru
Joined: 14 Jun 2007 Posts: 10611 Location: Sanford, NC
Posted: Wed Sep 19, 2012 5:48 pm Post subject: Re: Replacement head bolts |
| TheOldHokie wrote: | (quoted from post at 01:11:51 09/20/12) | AllisG wrote: | | (quoted from post at 13:51:18 09/19/12) Puting new pistons and crank in a ford 8n and I did this at my local high school and somebody stole 1 of the head bolts for the engine. But just 1 probly throw it across our shop at somebody... As for the question Is the bolts used to hold the head on a certain grade or a special bolt or can i go to the local true value and pick up a simple bulk bolt and put in the engine? |
TOH |
Are wack a 1/8 off... are use it anywhere but the manifold side of the engine.... |
| Back to top |
NOXJohn Long Time User
Posted: Thu Sep 20, 2012 2:57 am Post subject: Re: Replacement head bolts |
I purchased replacement head bolts from Fastenal. They were 7/16"-14X2&1/2" yellow zinc finish SAE j429 Grade 8 Hex Cap Screws Part#0115163. The was cost $0.896/each. All the head bolt holes were open into the water jacket in the three 8Ns I have rebuilt. If any hole looks blocked dig around and see if it is not just years of corrosion. I used a washer only because the head on the new bolt was not as big as the original and I liked the look. The washer from Fastenal was a 7/16" yellow zinc finish SAE Tru-Hardened flat washer Part# 1133816. The cost was $0.1912/each. I used Teflon paste seal on all bolts. I did not cut anything off any of the bolts. |
| Back to top |
YT Home
| Tractor Manuals
| Tractor Parts
| Forum Home
