| Author |
Message |
sHan tn Regular
Posted: Wed Sep 19, 2012 10:34 am Post subject: this is my 8N |
its not pretty but it does the job (most of the time lol) i have to look up the number to see for sure but they said it was a 1948 with a number of *8N188042
| Back to top |
Athrawn17 Regular
Posted: Wed Sep 19, 2012 10:38 am Post subject: Re: this is my 8N |
I have the same mower on mine. Do you notice any bog on the tractor when you get into some longer grass? |
| Back to top |
sHan tn Regular
Posted: Wed Sep 19, 2012 10:44 am Post subject: Re: this is my 8N |
if the grass gets any taller then 6-8" it starts to
bog down some so i just up the throttle and take it
down to second gear and it does fine, its a 6'
mower so its a tad big for it but for mowing "yard
grass" like i do it works great. |
| Back to top |
jackinok Tractor Expert
Posted: Wed Sep 19, 2012 10:54 am Post subject: Re: this is my 8N |
looks far better than any of mine! |
| Back to top |
mgriff543 Regular
Posted: Wed Sep 19, 2012 1:09 pm Post subject: Re: this is my 8N |
Nice tractor, You mow in third gear? Wow you're a braver man then I
Mike |
| Back to top |
sHan tn Regular
Posted: Wed Sep 19, 2012 2:54 pm Post subject: Re: this is my 8N |
yes all the time it does just great. sometimes i
run it in second if the grass is too tall or the
blades are dull, other than that its 3rd and less
than half throttle |
| Back to top |
Jimbo's 8n Regular
Posted: Thu Sep 20, 2012 2:20 am Post subject: Re: this is my 8N |
I mow in 3rd gear as well. I bought the same mower (6" kingkutter) brand new this past june and so far have had 2 tires seperate from the wheel on it. Was just wondering if you had any problems. (Also the replacement wheels sold at TSC will not fit it. Had to order them from kingkutter direct. |
| Back to top |
Roger in Iowa Long Time User
Posted: Thu Sep 20, 2012 6:53 am Post subject: Re: this is my 8N |
I have the heavy duty version. It has a double vee belt with the bonded backside. Original belt was crap. Vee pieces came out in chunks but it WAS NOT WARRANTY per TSC as belts are not warranted!
Replaced belt with known supplier and it is starting to chunk out after several years.
No problem with wheels/tires except zerk fittings.
Have failed one blade spindle shaft and bearings.
I mow in first, second and third depending on grass height, but with throttle over the upper screw. |
| Back to top |
souNdguy Tractor Guru
Posted: Thu Sep 20, 2012 7:32 am Post subject: Re: this is my 8N |
looks fine to me.
looks like a later screw on trans knob.. but is a front mount dizzy. |
| Back to top |
sHan tn Regular
Posted: Thu Sep 20, 2012 8:23 am Post subject: Re: this is my 8N |
no trouble out of it other than there is a weld broke on the right arm for the wheel, il weld it back and all is well, its 3 years old and the tires are holding up well 1 goes flat every now and then |
| Back to top |
Jimbo's 8n Regular
Posted: Thu Sep 20, 2012 9:23 am Post subject: Re: this is my 8N |
Wish my mower had the inflatable tires. Mine are solid rubber and once they come off the rim, you"ll never get them back on. |
| Back to top |
sHan tn Regular
Posted: Thu Sep 20, 2012 10:30 am Post subject: Re: this is my 8N |
if they are hollow rubber wheels take the tire off and drill a hole in the rim for a tube and put it back together  |
| Back to top |
1951 8N Regular
Posted: Thu Sep 20, 2012 2:40 pm Post subject: Re: this is my 8N |
| soundguy wrote: | looks fine to me.
You could have a screw on shift knob with a front mount distributor if it was a 1950, but it would also have the newer streering box which his doesn't have. |
| Back to top |
Britcheflee Long Time User
Joined: 20 Aug 2007 Posts: 1410 Location: Placerville California
Posted: Thu Sep 20, 2012 9:28 pm Post subject: Re: this is my 8N |
| mgriff543 wrote: | (quoted from post at 14:09:50 09/19/12) Nice tractor, You mow in third gear? Wow you're a braver man then I
Mike |
I agree on my rough bumpy and hilly property I would think 3rd would be rather scary - 2nd for me cruising along.
lee |
| Back to top |
Jimbo's 8n Regular
Posted: Fri Sep 21, 2012 12:02 am Post subject: Re: this is my 8N |
Thanks, but unfortunately they"re solid rubber tires. |
| Back to top |
