| Author |
Message |
Briar Hill Brittanys Regular
Posted: Wed Sep 19, 2012 1:08 pm Post subject: Tire Size for JD/VB FB Drill |
What size tire is supposed to be used on an FB model drill. The ones on it now, and were on it when I bought ir are 9.50 - 15 implement tires, and seem pretty tall. Sometimes I can look back and see a boot or two in the air an inch or two. On the places that are nice and level I don't see that. Get in any parts of a field that have small ridges and the seed drops on the surface. I guess the cover chains drag enough dirt over the seed to get it to germinate. Mark |
| Back to top |
dmiller Long Time User
Posted: Wed Sep 19, 2012 1:31 pm Post subject: Re: Tire Size for JD/VB FB Drill |
I'll have to check when I get home, but I think the ones on mine are 6.0 by 15. |
| Back to top |
RickB Tractor Guru
Posted: Wed Sep 19, 2012 2:47 pm Post subject: Re: Tire Size for JD/VB FB Drill |
Wrong tire will also affect seeding rates. You may be able to download a parts manual from mother Deere.
Deere Parts
| Back to top |
Brendon-KS Long Time User
Posted: Wed Sep 19, 2012 3:41 pm Post subject: Re: Tire Size for JD/VB FB Drill |
I have 7.00-15 truck tires on my B drill and they seem to be about right. |
| Back to top |
Mike neia Guest
Posted: Wed Sep 19, 2012 7:08 pm Post subject: Re: Tire Size for JD/VB FB Drill |
The book for my B calls for 6.70-15. |
| Back to top |
Don-Wi Tractor Guru
Joined: 12 Aug 2002 Posts: 7591 Location: Hilbert, Wi
Posted: Thu Sep 20, 2012 2:26 am Post subject: Re: Tire Size for JD/VB FB Drill |
I think ours has 7.50 x 15, which is the largest tire size listed in the manual.
Donovan from Wisconsin |
| Back to top |
Tx Jim Tractor Guru
Joined: 14 Feb 1999 Posts: 13131 Location: Coyote Flats,Tx
Posted: Thu Sep 20, 2012 2:30 am Post subject: Re: Tire Size for JD/VB FB Drill |
The 6 lug wheel for a FB drill is JD894(subs to a JD680) which is a 5"X15" so 6.70X15 is correct for a FB also. As stated a larger diameter tire will cause drill to put out less seed than chart shows. |
| Back to top |
Leroy Tractor Guru
Joined: 09 Jan 1998 Posts: 9422 Location: Wapakoneta, Ohio
Posted: Thu Sep 20, 2012 4:21 pm Post subject: Re: Tire Size for JD/VB FB Drill |
I had 7:60 x 15" on mine |
| Back to top |
YT Home
| Tractor Manuals
| Tractor Parts
| Forum Home
