| Author |
Message |
ryan hopkes Guest
Posted: Wed Sep 19, 2012 4:59 pm Post subject: minneapolis moline g6 help |
i need help i got a g6 diesel that has been totaly rebuilt... im getting antifreez in the oil any ideas on what might cause this... i know there is alot of things that might cause this but any ideas on whats most likely??? i dont think its a head gasket there brand new... with reserficed heads and jugs.. |
| Back to top |
Cliff Nelson Long Time User
Posted: Wed Sep 19, 2012 5:52 pm Post subject: Re: minneapolis moline g6 help |
Did you do anything with the water pump? I would check that first as a bad seal can put anti freeze in the oil. |
| Back to top |
ryan hopkes Guest
Posted: Thu Sep 20, 2012 4:42 am Post subject: Re: minneapolis moline g6 help |
i was thinkin about that i think im going to pull the oil pan off and clean it up the crank case and then see if it drips from anywhere do they have sleaves in that motor? |
| Back to top |
Howard H. Tractor Expert
Joined: 28 Feb 2002 Posts: 1792 Location: North Texas Panhandle/OK Panhandle
Posted: Thu Sep 20, 2012 8:42 am Post subject: Re: minneapolis moline g6 help |
How much water is getting in?? I would second Cliff"s idea of checking the water pump. They are pretty prone to problems, though they typically will leak to the outside more commonly than the inside (at least on 605s & old style & HD 800s )...
If it gets hot on you very quickly and/or runs hot with bubbles in the water, might have a cracked head or bad gasket...
Howard |
| Back to top |
MMUBMM Guest
Posted: Thu Sep 20, 2012 9:56 am Post subject: Re: minneapolis moline g6 help |
Retorque the head bolts. |
| Back to top |
ryan hopkes Guest
Posted: Thu Sep 20, 2012 10:06 am Post subject: Re: minneapolis moline g6 help |
well i just found out there is alot more then just that to worry about... whoever rebuilt this motor had no clue what they were doing... i heard a loud clicking noise from the valve cover and i took the breather off and looked down in there and the whole rocker setup was sideways so i took the valve cover off and three push rods werent even conected to the rockers.. they have been sitting in there beating the hell out of everything and the rocker toweres are snapped right off... this motor has alot more problems then just that now.. and i never owned a 6 cylinder moline befour soo i didnt know it wasnt running right.. and since its a diesel everything makes noise soo i didnt hear it till i took the hood off and i havent even owned this tractor for a week yet.. im pist |
| Back to top |
ryan hopkes Guest
Posted: Thu Sep 20, 2012 10:48 am Post subject: Re: minneapolis moline g6 help |
anyone know the best place to get parts? |
| Back to top |
Posted: Thu Sep 20, 2012 12:27 pm Post subject: Re: minneapolis moline g6 help |
Yikes!
Sounds like you've got a problem...
Does it look like the heads have ever gotten hot?? Is the paint and/or grease burned off them??
If so, they might be cracked causing your water issue... And or caused a valve guide to seize up on the valve breaking the rocker arms...
Howard |
| Back to top |
Blackland Dan Regular
Posted: Thu Sep 20, 2012 5:08 pm Post subject: Re: minneapolis moline g6 help |
Ryan, Cliff is right about the water pump seal. It happened to me on my G6 and it would dump a lot of water into the crankcase. I'm not sure what your water problem will turn out to be, but, don't forget the water pump. A good place to get Moline parts is from Welters, 417-498-6496. |
| Back to top |
red bull New User
Posted: Thu Sep 20, 2012 5:55 pm Post subject: Re: minneapolis moline g6 help |
I had the same problem with mine. It was the water pump seal. |
| Back to top |
ryan hopkes Guest
Posted: Thu Sep 20, 2012 7:24 pm Post subject: Re: minneapolis moline g6 help |
yea there rusty but the heads and jugs have been baked out when it was rebuilt but i dont think antifreez is getting in the cylinder tho beacuse its not hydro locking or no white smoke and it has brand new valvs and guides and they all seem to be good |
| Back to top |
ugly UB Regular
Posted: Sat Sep 22, 2012 5:54 am Post subject: Re: minneapolis moline g6 help |
ryan I beleve we live close to each other reply to the email and i will give you my phone number i can help you out |
| Back to top |
ryan hopkes Guest
Posted: Sun Sep 23, 2012 10:23 am Post subject: Re: minneapolis moline g6 help |
i got it running good now it was fuel in the oil not antifreez and i think i got most of the bugs out of her for the nowthen pull next weekend thank you everyone for the help we got 3 molines and now i know where to get some great advice we got a g6, gb, and a strange u |
| Back to top |
