| Author |
Message |
showdown Regular
Posted: Thu Sep 20, 2012 12:56 pm Post subject: No tubes i n tires???????????? |
How much work is it to put on 15.5x 38 8 ply tires with no tubes,or is it worth doing? |
| Back to top |
johndeereman Tractor Expert
Posted: Thu Sep 20, 2012 4:48 pm Post subject: Re: No tubes i n tires???????????? |
A lot depends on how stretched your tires are the farther the better. You"ll want them to just about go on the bead themselves otherwise you"ll have to use dangerouse either or something along those lines. Only thing to gain by this is about a 100# weight loss still will be rather difficult to keep air in them if there"s any rust or pitting around beads on rims |
| Back to top |
Eldo case Long Time User
Posted: Fri Sep 21, 2012 5:48 am Post subject: Re: No tubes i n tires???????????? |
Not a bad job. Use silicone on beads. Have mounted tires with boots and held tubless. |
| Back to top |
Bad Birdie Regular
Joined: 22 Mar 2010 Posts: 49 Location: Stockton, Missouri
Posted: Fri Sep 21, 2012 10:10 pm Post subject: Re: No tubes i n tires???????????? |
To answer your question about is "it worth doing", that is up to you. On a 2600 pound tractor I think it is definitely worth doing, as the weight of the tubes is a significant amount...however if you are pulling a 6 or 7000 pound tractor, it don"t make that much difference. Everone has their own opinion though. Good luck to ya. |
| Back to top |
ricky c Regular
Joined: 05 Mar 2009 Posts: 270 Location: west columbia sc
Posted: Tue Sep 25, 2012 10:58 am Post subject: Re: No tubes i n tires???????????? |
i have 18.4 tubeless. just cut you 6 pieces of 2x2 wood 2 inchs longer than the rim width about 4 days before and spread out the beads. they stay pretty good and help you mount them. mark you tire and rim to make sure the dont spin on the rim when you pull. may have to screw them |
| Back to top |
YT Home
| Tractor Manuals
| Tractor Parts
| Forum Home
