Tractor
 Parts
Yesterday's Tractors
Tractor Manuals
Shop for Parts:
Project Journal
Tractor Town
Show & Pull Guide
Related Sites
The Tractor Shed
TractorLinks.com
Ford N-Series Club
Garden Tractors
Today's Tractors
Classic Trucks
Kountry Life
subscribe
unsubscribe
Content Guide
Picture List - TOC
Ad Archives - TOC
Manuals - TOC
TO20 3 point stopped working
Post new topic    Yesterday's Tractors Forum Index -> Harry Ferguson
makoman
PostPosted: Fri Sep 21, 2012 7:51 am    Post subject: TO20 3 point stopped working Reply to specific post Reply with quote
My 3 point was lifting great and then just stopped lifting. I checked the fluid and it was milky brown. (The tractor was left outside for about a year, but now it will stay inside). I was going to change the fluid with NAPA mineral oil. What else should I do? Any filter or pick up to clean? What else should I do or check?
Thanks for the help.
John(UK)
PostPosted: Fri Sep 21, 2012 8:08 am    Post subject: Re: TO20 3 point stopped working Reply to specific post Reply with quote
There is no filter in this system and from your description it does have water in it. The Control Valve has stuck from your description and that is the problem, especially as the oil is like that.The oil needs changing when it is hot so it will drain all then crud out.Use Multi-grade 10W/30 oil, this will be a much better oil form your hydraulics to work in.
The Valve sticking, remove the Right Side round plate and you will see the Control Fork from the Lever hanging down, with the engine idling, using a screw driver, move the fork back-wards and for-wards GENTLY Do Not Force it, once the Fork move so will the Valve.Now it is possible tat the Fork has become detached from the Fork. Stop the engine and follow the Fork down into the oil with your Hand, at the bottom, there is a short "bar" between the two legs of the Fork, make sure that it is attached to BOTH legs of the Fork, if it has come out, open the fork a little and fit the "bar" between the Fork Legs. If it is a slack fit, you will need to squeeze the fork legs together slightly to hold it in place. DO NOT PUT YOUR HANDS INTO THE OIL IF THE ENGINE IS RUNNING If you want all this written out for you with a bit more detail, email me direct and I will send it...John(UK)...fergusontractors@hotmail.com
JPFL
PostPosted: Fri Sep 21, 2012 9:59 am    Post subject: Re: TO20 3 point stopped working Reply to specific post Reply with quote
FYI, should you need parts I have good used parts. Jim in FL 813-695-7039
