| Author |
Message |
Royse Tractor Expert
Posted: Sat Sep 22, 2012 4:23 pm Post subject: Which end up? Power steering ?? |
I posted this question and a couple pictures on the Ford forum this morning
but haven't gotten any responses yet.
I'm looking for advice on which way to install the power steering motor on my Jubilee.
I forget the brand name of the PS unit, it's aftermarket, came off an x00, 640 I think.
Ford Forum |
| Back to top |
TheOldHokie Tractor Guru
Joined: 08 Apr 2005 Posts: 5873 Location: Myersville, MD
Posted: Sun Sep 23, 2012 2:59 pm Post subject: Re: Which end up? Power steering ?? |
| Royse wrote: | (quoted from post at 20:23:38 09/22/12) I posted this question and a couple pictures on the Ford forum this morning
Ford Forum |
It's not a motor - it's a pump. I doubt it makes any operational difference but I would expect the hoses to connect from the bottom. I would not be at all sure it is bi-directional - most pumps are not.
TOH |
| Back to top |
Posted: Sun Sep 23, 2012 4:15 pm Post subject: Re: Which end up? Power steering ?? |
| TheOldHokie wrote: | (quoted from post at 18:59:55 09/23/12) | Royse wrote: | (quoted from post at 20:23:38 09/22/12) I posted this question and a couple pictures on the Ford forum this morning
Ford Forum |
TOH |
Thanks TOH, maybe I'm not using the correct term for it.
This is the controlling valve in the power steering unit.
It mounts in the steering column, one hose coming from the pump,
one hose returning to the tank and two going to the cylinder that helps move the steering drag link.
The only diagram I've seen for this thing labeled it a motor, even though it
obviously does not work as one.
| Back to top |
Kurt-NEPA Long Time User
Joined: 05 Mar 2009 Posts: 737 Location: Tunkhannock, PA
Posted: Sun Sep 23, 2012 4:47 pm Post subject: Re: Which end up? Power steering ?? |
Is this what you are talking about Royse?
Maybe these pics will help.
| Back to top |
Posted: Sun Sep 23, 2012 5:34 pm Post subject: Re: Which end up? Power steering ?? |
Same idea Kurt, same "valve" function, but the one I have is aftermarket.
Here are the pictures.
First one is the way I think it should go, with the return on bottom.
Second one is just upside down, with the return hose off.
| Back to top |
Posted: Mon Sep 24, 2012 4:31 am Post subject: Re: Which end up? Power steering ?? |
| Royse wrote: | (quoted from post at 21:34:57 09/23/12) Same idea Kurt, same "valve" function, but the one I have is aftermarket.
My bad - sounded lik eyou were talking about the pump.
TOH |
| Back to top |
Posted: Mon Sep 24, 2012 6:37 am Post subject: Re: Which end up? Power steering ?? |
From you description Royse, it sounded like you had something different than I did, but it was worth a try.....
I hope you get it straightened out.
Kurt |
| Back to top |
Posted: Mon Sep 24, 2012 7:34 am Post subject: Re: Which end up? Power steering ?? |
Its hard to help someone who's not using the correct terminology.
I certainly appreciate the effort. |
| Back to top |
Posted: Mon Sep 24, 2012 7:37 am Post subject: Re: Which end up? Power steering ?? |
It's a different style Kurt, but those pictures definitely help explain what
I'm working on and where.
Thanks for posting them. |
| Back to top |
JMOR Tractor Guru
Posted: Mon Sep 24, 2012 8:01 am Post subject: Re: Which end up? Power steering ?? |
Royce, if you can't find any info on that unit & have to go it on your own, then you might learn something by applying rotational forces to shafts & looking for flow paths to open & close (air pressure). From others I have seen, there may be a check valve in the line from pump to prevent back flow into pump output. If in yours, that might yield a clue. |
| Back to top |
YT Home
| Tractor Manuals
| Tractor Parts
| Forum Home
