| Author |
Message |
PaulKin IL Guest
Posted: Sat Sep 22, 2012 6:58 pm Post subject: Ford 3000 Question |
Anyone know the oil capacity of a '72 Ford 3000 with a gas engine? The operators manual says 8 qts. but when I put that much in it shows way over full on the dipstick. |
| Back to top |
old Tractor Guru
Joined: 12 Mar 2000 Posts: 50401 Location: Lake of the Ozarks area of MO
Posted: Sat Sep 22, 2012 7:49 pm Post subject: Re: Ford 3000 Question |
Well did you start it??? The oil filter holds about 1 qt so till you start it up yep you get and over full reading. Just double checked the FO-31 manual just to be sure and it does say 8 also so that is not factoring in the filter |
| Back to top |
PaulKin IL Guest
Posted: Sat Sep 22, 2012 8:20 pm Post subject: Re: Ford 3000 Question |
Thanks old. Yes, I pulled the coil wire and turned it over to fill the oil filter, it has a spin-on so it holds less than a quart and that brought it down to about an inch and a half over the full line. Just worried about the end of the rods foaming up the oil. |
| Back to top |
Royse Tractor Expert
Posted: Sat Sep 22, 2012 8:25 pm Post subject: Re: Ford 3000 Question |
I'm not up on the 3000's but I'd be a might worried about an inch and a half over full.
Is this a new to you tractor? Might have the wrong dipstick in it? |
| Back to top |
Sean in PA Tractor Expert
Joined: 27 Feb 2008 Posts: 1671 Location: Southeast PA
Posted: Sun Sep 23, 2012 4:35 am Post subject: Re: Ford 3000 Question |
| PaulKin IL wrote: | | (quoted from post at 22:58:52 09/22/12) Anyone know the oil capacity of a '72 Ford 3000 with a gas engine? The operators manual says 8 qts. but when I put that much in it shows way over full on the dipstick. |
That's odd, because my owner's manual says 7 quarts with a filter change and 6 quarts without a filter change for all '65-'75 3 cylinder ag models, regardless of gas or diesel. It specifically lists the 2000, 2110, 3000, 4000, 4000SU and 4110, and the oil capacity is the same for all of them. |
| Back to top |
Hogleg Long Time User
Joined: 05 Mar 2009 Posts: 741 Location: Near Salem, Ill
Posted: Sun Sep 23, 2012 4:42 am Post subject: Re: Ford 3000 Question |
Mine says 7 quarts also but never have gotten it to take that much. I drain, change the filter, fill 6, then start it, then top it off, usually takes a bit more than a pint to hit the full mark. I hold onto the rest, check it often, but the darn thing never seems to need it. always on full. Was rebuilt by the dealer in 2004.
John |
| Back to top |
Ultradog MN Tractor Guru
Joined: 22 Apr 2001 Posts: 12414 Location: Twin Cities
Posted: Sun Sep 23, 2012 5:49 am Post subject: Re: Ford 3000 Question |
You can check the length and markings of your dipstick against this photo.
I would not run it that over full.
| Back to top |
freds Regular
Posted: Sun Sep 23, 2012 6:30 am Post subject: Re: Ford 3000 Question |
The manual for my 3000 clearly states that the oil capacity is 8 qt with filter and 6 without under the specification sheet. However, this will overfill it by approximately one quart. The number on the back of the manual is SE 3225 86850 and I am pretty sure is was the one that came with the tractor. |
| Back to top |
PaulKin IL Guest
Posted: Sun Sep 23, 2012 7:10 am Post subject: Re: Ford 3000 Question |
Thank you all for responding. Great idea posting the picture of the dipstick with the ruler UltraDog, mine does not look like that. It has 2 full marks one on each side of "FULL" so it looks like someone changed the dipstick in the last 40 years.
I'm sure part of the confusion on the capacity is the fact that they changed from the old cartridge type filter that took 2 quarts to fill to the spin-on filters. Also found it interesting that Fram's web site showed a PH16 filter for the gas engine and a PH8A for the diesel. |
| Back to top |
crazylocha Long Time User
Joined: 14 Oct 2010 Posts: 539 Location: Reddick(Ocala), FL
Posted: Sun Sep 23, 2012 2:34 pm Post subject: Re: Ford 3000 Question |
Paul, I agree about the photo, since I am the nutter who broke the one P.O. had soldered together and used. Had to replace at that point, but was questioning proper level. Figured if on there good, then is OK.
Am using a ph8a on my gasser. Seems like last one and current are doin OK by the condition of oil. It was also what P.O. had on there when I took it off.
P.s. Thx for the pic UD
| Back to top |
flyingace Regular
Posted: Sun Sep 23, 2012 5:17 pm Post subject: Re: Ford 3000 Question |
| PaulKin IL wrote: | | (quoted from post at 19:58:52 09/22/12) Anyone know the oil capacity of a '72 Ford 3000 with a gas engine? The operators manual says 8 qts. but when I put that much in it shows way over full on the dipstick. |
Check the condition of the oil pan. If it's been dented in, the shape may only hold 6 quarts rather then 8. |
| Back to top |
Fordfarmer Tractor Guru
Joined: 12 Dec 2005 Posts: 6525 Location: Ladysmith, WI
Posted: Mon Sep 24, 2012 5:44 am Post subject: Re: Ford 3000 Question |
Just to add to the confusion... some factory dipsticks have the two marks you refer to - my 7000 and 7600 both do. As you have a spin-on filter, it should take 7 quarts. |
| Back to top |
RodinNS Tractor Guru
Posted: Mon Sep 24, 2012 3:46 pm Post subject: Re: Ford 3000 Question |
As long as it's in the 6-9 qt range and the stick shows full I wouldn't get too twisted about it.
Rod |
| Back to top |
Texasmark1 Tractor Expert
Posted: Tue Sep 25, 2012 4:47 am Post subject: Re: Ford 3000 Question |
Measure it soon after you shut the engine down. The oil filter drains back into the crank case and upon checking cold, like first thing in the morning before you crank, it will read over full. BTDT
Mark |
| Back to top |
Posted: Tue Sep 25, 2012 4:52 am Post subject: Re: Ford 3000 Question |
Another thought: I had 2 ea 3000's once. One had a cartridge which was very large and the other a spin on that used a Motorcraft FL-1A. The volume of the spin on was much smaller than the cartridge type. I'm assuming that the manual was written for the early (mine was '65, cartridge a '66) model 3000. If you have the spin on, it could read 1 qt over full anyway.
Mark |
| Back to top |
