| Author |
Message |
ARHunter Regular
Posted: Sun Sep 23, 2012 6:28 am Post subject: Help Identify Old Bushog |
I am trying to figure out what model Bushog this is. I know it is probably at least 40-50 yrs old. Any help would be appreaciated.
Also, the input shaft seal leaks and I have read you can fill these gear boxes with grease. Would it be better to do that or fix the seal? Thanks
| Back to top |
BigMarv1085 Regular
Posted: Sun Sep 23, 2012 6:39 am Post subject: Re: Help Identify Old Bushog |
The gear box looks the same as a Bushhog 706, have you tried to run the numbers on the back bottom of the gear box |
| Back to top |
the real roger Regular
Posted: Sun Sep 23, 2012 6:48 am Post subject: Re: Help Identify Old Bushog |
What size is it? If it is 5 foot it could be a model 12 |
| Back to top |
ARHunter Regular
Posted: Sun Sep 23, 2012 6:54 am Post subject: Re: Help Identify Old Bushog |
| the real roger wrote: | | (quoted from post at 15:48:17 09/23/12) What size is it? If it is 5 foot it could be a model 12 |
It is 5 foot. I think it may be a model 12 just wasn't sure. What about putting grease in the gear box. Any opinions on this? |
| Back to top |
James Howell Tractor Guru
Joined: 06 Mar 2006 Posts: 5562 Location: Hutchins, TX
Posted: Sun Sep 23, 2012 6:59 am Post subject: Re: Help Identify Old Bushog |
I agree with the real roger that it is a 5ft Model 12 mower.
Got one just like it down by the equipment shed. |
| Back to top |
Posted: Sun Sep 23, 2012 7:08 am Post subject: Re: Help Identify Old Bushog |
You can use Corn Head Grease that is available from Deere.
Used it to stop a leak on the JD #5 sickle mower.
Used it a couple of weeks ago to stop a leak on the 7ft Corsicana rotary cutter.
Hope this helps. |
| Back to top |
ARHunter Regular
Posted: Sun Sep 23, 2012 7:12 am Post subject: Re: Help Identify Old Bushog |
Thanks for all your help. I can change the seal on the input shaft, but if the thin grease will work and not leak that would be a much easier solution . |
| Back to top |
Billy NY Tractor Expert
Posted: Mon Sep 24, 2012 8:50 am Post subject: Re: Help Identify Old Bushog |
Besides the surface rust, it sure looks like it had an easy life and that is definitely an older gearbox judging by the looks. I can't believe how straight the deck is, not even a circle imprint from the blades like most eventually get.
See what info you can get off it, might find literature for it on ebay or similar.
There was a post on here about Grease vs 80W-90WT oil in these, my old Rhino SE-6 actually called for 0 or 00 which is heavier than 80W-90, less viscous and almost like track roller lube which is a stringy tacky type lube, almost reminds me of chainsaw bar oil.
Someone made a point about grease that I thought was good, I would not use it, unless nothing else was available, fix the seal and used the appropriate lube, its designed for splash lube applications which is what the differential/gearbox is. One of the reasons I would prefer to use the heavier oils is for maintenance, mixing greases and oils, incompatible soap bases and whatever else, has the potential to make a mess, when I want to change the oil on mine, I flip it over, drain it, and refill with Lucas 80W-90 or whatever grade, (I forget at the moment) but is stays clean and does not leak, I'm sure the seal has plenty of miles on it too ! |
| Back to top |
ARHunter Regular
Posted: Mon Sep 24, 2012 1:37 pm Post subject: Re: Help Identify Old Bushog |
| Billy NY wrote: | (quoted from post at 17:50:54 09/24/12) Besides the surface rust, it sure looks like it had an easy life and that is definitely an older gearbox judging by the looks. I can't believe how straight the deck is, not even a circle imprint from the blades like most eventually get.
Yeah, I guess I should go ahead and replace the seal. It shouldn't be too much trouble.
It seems to be in fairly good condition except for the deck being cracked in a couple of spots where the front vertical bars connect. I beefed that area up with some 2"x2" angle iron. Replaced the bearings and seals in the tail wheel hub and put on a new tail wheel. Used it all day last Saturday and never had a problem. |
| Back to top |
John Mason, Michigan Guest
Posted: Sat Sep 29, 2012 5:16 pm Post subject: Re: Help Identify Old Bushog |
Any of you guys know anything about Mono Mfg, brush hogs? |
| Back to top |
YT Home
| Tractor Manuals
| Tractor Parts
| Forum Home
