| Author |
Message |
Mr Frank Guest
Posted: Sun Sep 23, 2012 9:49 am Post subject: 2000 gasser |
Well, got "big blue" busted off yesterday with my auxillary gas tank and rebuilt carb installed, runs fairly well, does sputter a bit when the throttle is opened, but if you pull choked it doesn't the fuel pump is unhooked and just gravity feeds from tank would that cause that? And also do I still need to use an orc when bushhogging??? thanks in advance |
| Back to top |
mr frank Guest
Posted: Sun Sep 23, 2012 9:50 am Post subject: Re: 2000 gasser |
Don't think I'm important enought on here to be addressed as mister but this is a new puter and I don't know my password lol |
| Back to top |
Ultradog MN Tractor Guru
Joined: 22 Apr 2001 Posts: 12567 Location: Twin Cities
Posted: Sun Sep 23, 2012 10:07 am Post subject: Re: 2000 gasser |
When you mention fuel pump I assume you have a 3 cylinder model?
If you still have the holley carb it probably does require higher than gravity fuel pressure to operate properly.
ORC depends on whether you have live pto or not.
With lpto you don't need an orc. |
| Back to top |
Mr Frank Guest
Posted: Sun Sep 23, 2012 1:11 pm Post subject: Re: 2000 gasser |
Don't know how to tell if I have live PTO all I can say is that the PTO does stop when clutch is pressed, but it doesn't have to be depressed to engage the PTO. Mostly what I have ever been on are N series. Thanks |
| Back to top |
Posted: Sun Sep 23, 2012 2:56 pm Post subject: Re: 2000 gasser |
On a 2000 with lpto when you push the clutch halfway down the tractor will stop.
If you push it all the way down the pto will stop.
Tell us what speed your tractor has 4, 6 or 8
or better yet post all three lines of code that are stamped just above and aft of the starter.
Folks here will be able to tell you exactly what you have.
You might have to scrape off some paint to see them.
| Back to top |
souNdguy Tractor Guru
Posted: Mon Sep 24, 2012 4:28 am Post subject: Re: 2000 gasser |
you should be using the clutch to engage the pto.
with no load on the pto it will engage without the clutch.. but with a laod on it it will grind.
use the clutch |
| Back to top |
Mr Frank Guest
Posted: Mon Sep 24, 2012 1:38 pm Post subject: Re: 2000 gasser |
I have the 12 forward 3 reverse transmission, which i might add might sound impressive to some, I can't imagine you ever needing to use anything other than low range, it is an extremely high geared tractor |
| Back to top |
Sean in PA Tractor Expert
Joined: 27 Feb 2008 Posts: 1716 Location: Southeast PA
Posted: Mon Sep 24, 2012 2:59 pm Post subject: Re: 2000 gasser |
12 forward and 3 reverse? Sounds like a 4 speed with a Sherman combo. Is there a single stick shift on top that has 4 forward and 1 reverse speeds, plus a handle down on the left side of the transmission that shifts between low, medium and high range? If that's what you have, then it's a transmission driven PTO, and yes, you need an Over Run Clutch (ORC) when running a bush hog. |
| Back to top |
YT Home
| Tractor Manuals
| Tractor Parts
| Forum Home
