| Author |
Message |
JohnDeere2Cylinder Regular
Posted: Sun Sep 23, 2012 6:48 pm Post subject: Backyard Mechanic Brains Needed |
Please help. I need to put a clutch in line between an automatic transmission and a rear end in a tractor and truck pulling eliminator. When a tractor pulls me down the track, I want to stop the automatic transmission from running backwards. Is there an easy fix using something like a 12 volt electric clutch on the shaft like from a chopper head or a combine head or something from a junkyard? Thanks. |
| Back to top |
VicS Tractor Expert
Posted: Sun Sep 23, 2012 7:25 pm Post subject: Re: Backyard Mechanic Brains Needed |
What about a four wheel drive transfer case. Will just bolt to your auto or will have to change to a 4X4 auto and transfer case. Late models are electric. Early ones use a lever. just put it in Neutral. |
| Back to top |
504 Tractor Expert
Posted: Sun Sep 23, 2012 7:35 pm Post subject: Re: Backyard Mechanic Brains Needed |
This may be a stretch but fire trucks (some)have a clutch to hook the drive shaft to the water pump and bypass the rear end. |
| Back to top |
Cale Guest
Posted: Mon Sep 24, 2012 5:38 am Post subject: Re: Backyard Mechanic Brains Needed |
Use a manual trans with cable or hyd.shift to operator platform also this will give you a reduction for soft tracks 6188304992 |
| Back to top |
Posted: Mon Sep 24, 2012 5:55 am Post subject: Re: Backyard Mechanic Brains Needed |
Thanks. All good ideas so far. What's the best way to add a short (I don't have a lot of room) four wheel drive transfer case that I can shift into neutral. It's just that I don't want the extra weight and mass to bounce around on the end of my transmission. I only want to add a neutral. |
| Back to top |
Justin C. New User
Posted: Mon Sep 24, 2012 9:51 am Post subject: Re: Backyard Mechanic Brains Needed |
What size axles have you got under the sled? A lot of us use 2 speeds and machine one side off so you have neutral/low or high. |
| Back to top |
olddog Tractor Expert
Posted: Mon Sep 24, 2012 11:09 am Post subject: Re: Backyard Mechanic Brains Needed |
Will ya ever need reverse in the automatic?
If NOT, then mebbe a simple overrunning pto sprag clutch would woik?
YMMV
Void where prohibited by lawr
But WAIT, for only 19.95 we will double yer order!
Supplies are limited. |
| Back to top |
baldwin racing Regular
Posted: Mon Sep 24, 2012 4:19 pm Post subject: Re: Backyard Mechanic Brains Needed |
use a pto end out of a farmall m or something shorten down shaft and weld on what spline you need to run into trannsmission lock in or leave in newtral with simple small rod or lever to move rod on a pivot to lock it in?
kelly |
| Back to top |
VicS Tractor Expert
Posted: Tue Sep 25, 2012 4:56 pm Post subject: Re: Backyard Mechanic Brains Needed |
Just saw the ofset case with the chain in it off and patch the hole up. While you are welding a patch on put a 3/4 pipe plug in it so you can put a little oil back in. Not pretty but will work. |
| Back to top |
YT Home
| Tractor Manuals
| Tractor Parts
| Forum Home
