Author |
Message |
CaseIL New User
Posted: Sun Sep 23, 2012 8:34 pm Post subject: Case 400 diesel engine |
I am looking at purchasing a Case 400 diesel. It needs a different engine put in it. Does anyone know what engines that Case made would bolt into a 400. I was thinking that a 730 might but was not sure.
Thanks |
Back to top |
casecollectorsc Tractor Guru
Posted: Mon Sep 24, 2012 2:11 am Post subject: Re: Case 400 diesel engine |
730 engine will bolt right in. |
Back to top |
JHH Regular
Posted: Mon Sep 24, 2012 4:58 am Post subject: Re: Case 400 diesel engine |
730 or 830 engine should bolt right in, but the oil filter will interfere with the steering shaft.
DO NOT put the 400 oil filter on the 730/830 engine, make a spacer for between the filter base and the block and use the 730/830 filter.
Don't ask me how I know. |
Back to top |
1031D Tractor Expert
Joined: 31 Jul 2004 Posts: 2407 Location: Southern Wisconsin
Posted: Mon Sep 24, 2012 5:29 am Post subject: Re: Case 400 diesel engine |
What is wrong with the original engine? May be cheaper to fix that then buy another. |
Back to top |
CaseIL New User
Posted: Mon Sep 24, 2012 6:44 am Post subject: Re: Case 400 diesel engine |
The engine does not have heads, and has sat for 10 years with out
them. After sitting for the 10 years it is going to need a conplete
overhaul, plus the injector pump worked on. |
Back to top |
C. Amick Tractor Expert
Joined: 05 Mar 2009 Posts: 2383 Location: Wytheville, VA
Posted: Mon Sep 24, 2012 8:22 am Post subject: Re: Case 400 diesel engine |
Don't throw the old 400 engine and parts away. I'm sure someone on here could use them. |
Back to top |
Don Rudolph Tractor Expert
Posted: Mon Sep 24, 2012 2:20 pm Post subject: Re: Case 400 diesel engine |
A 700 or 800 engine will work as well. |
Back to top |
Posted: Mon Sep 24, 2012 7:40 pm Post subject: Re: Case 400 diesel engine |
I don't know what you have local but a 900/930 chain drive has the same heads as do the 500/600/700/800. I rebuilt my diesel a couple years ago for about $1200 complete with minor pump and injector work. |
Back to top |
