| Author |
Message |
young tractor Guest
Posted: Mon Sep 24, 2012 4:25 am Post subject: 1755 hydraulics |
Hi guys,
I am combining beans with a pull type combine on a 1755 diesel. The hydraulics are too fast and jumpy for raising and lowering the head. Can someone descripe in detail what and where I need to adjust the hyraulics to slow them down. I really appreciate any and all help. The more detailed you can be the better. Thanks a ton. |
| Back to top |
Don-Wi Tractor Guru
Joined: 12 Aug 2002 Posts: 7589 Location: Hilbert, Wi
Posted: Mon Sep 24, 2012 2:57 pm Post subject: Re: 1755 hydraulics |
On the back of the valve bank is a screw with a jam nut on it. The one that goes to the hoses you're using is the one you need to adjust. Loosen the nut and turn it in to make it a smoother/slower drop. Out to do the opposite.
Not sure there is much that can be done about the fast raising other than feathering the controls, unless you maybe use a bigger (diameter) cyinder that takes more oil to fill and extend.
Donovan from Wisconsin |
| Back to top |
J. Schwiebert Guest
Posted: Tue Sep 25, 2012 3:44 am Post subject: Re: 1755 hydraulics |
If I remember correctly you can also restrict the inlet flow. I take it you do not have a book. Does your combine have "skid plates"? Can the header be set to float. |
| Back to top |
mkirsch Tractor Guru
Posted: Tue Sep 25, 2012 6:21 am Post subject: Re: 1755 hydraulics |
You can also buy a flow limiting fitting to put in between the hose and cylinder. Instead of having a full-size hole, it has a tiny hole. |
| Back to top |
YT Home
| Tractor Manuals
| Tractor Parts
| Forum Home
