| Author |
Message |
Steve Fawks Regular
Posted: Mon Sep 24, 2012 5:11 am Post subject: M5 carb |
Just got my M5 back from overhaul and paint. It starts easy, idles fine, and runs with a load great....for a few minutes. Then it coughs and sputters like it's running out of gas until I let off the throttle.
New fuel line was run during restoration. I tried different adjustments on the carb. Any ideas? |
| Back to top |
pullingforfun Regular
Posted: Mon Sep 24, 2012 6:51 am Post subject: Re: M5 carb |
Could be some blockage in the tank it's self. Had that problem on our U |
| Back to top |
Craig Thompson New User
Posted: Mon Sep 24, 2012 9:18 am Post subject: Re: M5 carb |
I have also had a problem where I bought a new fuel bowl and the company that installed the outlet on the bowl installed teflon tape and was partially blocking fuel leaving the outlet.
This was a nightmare to find... but I would suspect it could even be at the connection points at the new fuel line? well its worth a try. |
| Back to top |
Steve Fawks Regular
Posted: Mon Sep 24, 2012 5:51 pm Post subject: Re: M5 carb |
Guess I"ll start by disconnecting the fuel line at the carb and checking the flow. If that"s good, I"ll move to carb itself. Thanks. |
| Back to top |
Alan K Tractor Expert
Posted: Mon Sep 24, 2012 6:10 pm Post subject: Re: M5 carb |
Odd thought but take a look in the tank as well....there may be an obstruction that floats over the hole occasionally that slows or stops the flow. |
| Back to top |
T.R.K. Guest
Posted: Tue Sep 25, 2012 8:15 am Post subject: Re: M5 carb |
When I had that problem it was fuel varnish glaze over most of the filter screen. Couldn't tell it when the screen was wet, but was obvious when dry. |
| Back to top |
Posted: Tue Sep 25, 2012 5:19 pm Post subject: Re: M5 carb |
Guess you allready said that didnt you...lol |
| Back to top |
Steve Fawks Regular
Posted: Tue Sep 25, 2012 7:42 pm Post subject: Re: M5 carb |
Is there anything that would come about with the tractor warming up? The first few minutes seem perfect? I have the fuel shut off when not using the tractor, it starts fine and runs for several minutes at whatever speed. Then it starts pitching a fit until I cut the throttle. |
| Back to top |
shinnery Long Time User
Joined: 18 Apr 2006 Posts: 969 Location: Hawley, Texas
Posted: Tue Sep 25, 2012 11:02 pm Post subject: Re: M5 carb |
All my M5s are propane or diesel, should it have a vented cap on the tank? My only gas moline is a Big Mo 400 M with the round tank.
Bryce
| Back to top |
YT Home
| Tractor Manuals
| Tractor Parts
| Forum Home
