| Author |
Message |
ryan hopkes Guest
Posted: Mon Sep 24, 2012 12:33 pm Post subject: GB poping out of gear |
i have a gb that i pull with and in the heavy classes it pops out of first gear and it wont stay in second if it pulls a disk or anything would a lose pinion gear cause this beacase i know that needs to be tightened up.. |
| Back to top |
puller1 Regular
Posted: Mon Sep 24, 2012 7:59 pm Post subject: Re: GB poping out of gear |
Most likely cause is the shifter rails wore between the notches and the notches them selves wore. Small welding rods and a flap disk on a 4 1/2" grinder can fix it up in about 30 minutes after you remove the tranny cover.
Other problem could be very worn gears or worn splined shaft the gears ride on. Most likely the shifter rails will be the problem. Make a bracket to hold the shifter in gear. |
| Back to top |
ryan hopkes Guest
Posted: Tue Sep 25, 2012 10:58 am Post subject: Re: GB poping out of gear |
i dont think its the shifting rods beacuse i fixed the detents and it helped alot but there is alot of noise from the trany |
| Back to top |
puller1 Regular
Posted: Tue Sep 25, 2012 1:12 pm Post subject: Re: GB poping out of gear |
Doesn't sound good. Sounds like you may need to pull the top cover and look for bad bearings. There is a needle bearing that goes in the inside of the pinion shaft on the end of the top shaft that the slider gears run on. |
| Back to top |
ryan hopkes Guest
Posted: Wed Sep 26, 2012 5:02 am Post subject: Re: GB poping out of gear |
is a u rear end the same as a gb? |
| Back to top |
redgems Regular
Posted: Wed Sep 26, 2012 6:48 am Post subject: Re: GB poping out of gear |
This is a "U" tranny with cover off.
My bearing at end of imput shaft inside larger gear was distroyed. I amagine it would of let shaft dropp and wobble.
Tony
| Back to top |
TimYates Regular
Posted: Wed Sep 26, 2012 9:59 am Post subject: Re: GB poping out of gear |
yep looks identical inside |
| Back to top |
1948 mm Guest
Posted: Sun Sep 30, 2012 11:41 am Post subject: Re: GB poping out of gear |
My gb does the same thing I just chain it into gear and run it! |
| Back to top |
YT Home
| Tractor Manuals
| Tractor Parts
| Forum Home
