Tractor
 Parts
Yesterday's Tractors
Tractor Manuals
Shop for Parts:
Project Journal
Tractor Town
Show & Pull Guide
Related Sites
The Tractor Shed
TractorLinks.com
Ford N-Series Club
Garden Tractors
Today's Tractors
Classic Trucks
Kountry Life
subscribe
unsubscribe
Content Guide
Picture List - TOC
Ad Archives - TOC
Manuals - TOC
Head Nuts OR Cap Screws
Post new topic    Yesterday's Tractors Forum Index -> Ford 9N, 2N, 8N
equeen
PostPosted: Mon Sep 24, 2012 2:25 pm    Post subject: Head Nuts OR Cap Screws Reply to specific post Reply with quote
Okay, so I don't know the difference between a "Cylinder Head Nut" @ 50-55 lbs torque and
a "Cylinder Head Cap Screw" @ 65-70 lbs torque.
That's why I'm posting this.
I believe that it's going to be "bolts" that come out when I remove the head on my '50 Ford 8N in the morning. Then replace the head gasket and put the "bolts" back in as specified on pg 130 of the Ford Service Manual. What's the torque on these "bolts" and what's a "cap screw". I know what a nut is - me.
Thanks.
Jock(OR)
PostPosted: Mon Sep 24, 2012 3:16 pm    Post subject: Re: Head Nuts OR Cap Screws Reply to specific post Reply with quote
A "Cap Screw" is a fancy name for a bolt.
Early engines had studs (threads on both ends) that stayed (or were supposed to stay) in the block when the nuts were removed to remove the head. The torque values for "nuts" apply to these.
If you have bolts holding on the head, use the "cap screw" torque value.
TheOldHokie
PostPosted: Mon Sep 24, 2012 3:19 pm    Post subject: Re: Head Nuts OR Cap Screws Reply to specific post Reply with quote
equeen wrote:
(quoted from post at 18:25:49 09/24/12) Okay, so I don't know the difference between a "Cylinder Head Nut" @ 50-55 lbs torque and
Thanks.
Loosely a "hex head cap screw" is a hex head bolt.
The "technical" difference between a "screw" and a "bolt" is defined by ASME B18.2.1 and is exceedingly detailed and arcane. If you really want to go there a concise summary of the principle differences is provided by Machinery's Handbook.
TOH
R Geiger
PostPosted: Mon Sep 24, 2012 3:44 pm    Post subject: Re: Head Nuts OR Cap Screws Reply to specific post Reply with quote
I assume you are going to check to make sure the head is not warped before you re-install it.
equeen
PostPosted: Mon Sep 24, 2012 4:53 pm    Post subject: Re: Head Nuts OR Cap Screws Reply to specific post Reply with quote
Local engine shop can check for warped head.
Anything a country boy with no fancy shop can do to check for warped head?
TheOldHokie
PostPosted: Mon Sep 24, 2012 5:16 pm    Post subject: Re: Head Nuts OR Cap Screws Reply to specific post Reply with quote
equeen wrote:
(quoted from post at 20:53:10 09/24/12) Local engine shop can check for warped head.
All you need is a high quality straight edge and a feeler gauge. Then follow the easy instructions in the link below. A quality (.001) machinist's straight edge will run you $40 and up.
How to Measure Head for Warpage
For a Ford flathead anything under .005 is fine.
TOH
tn8n
PostPosted: Mon Sep 24, 2012 5:19 pm    Post subject: Re: Head Nuts OR Cap Screws Reply to specific post Reply with quote
if you have a good undamaged (not bent, dinged, etc.) metal straightedge or ruler, you can turn the head upside down and hold the straightedge along the mating surface of the head in several places. if you can see daylight under it you'll know it's warped. look longways along the edges and side-to-side between cylinders. won't be super super accurate, but if you can't or don't want to take it to a shop it can't hurt.
R Geiger
PostPosted: Mon Sep 24, 2012 6:17 pm    Post subject: Re: Head Nuts OR Cap Screws Reply to specific post Reply with quote
I use a good straight edge ruler long enough for head. If warped you will see it and then take it to the machine shop for milling. If too much is taken off the pistons may hit head requiring more work. If milled check with no gasket and no bolts and turn engine over and watch head for movement.
