| Author |
Message |
david1 Guest
Posted: Mon Sep 24, 2012 4:05 pm Post subject: What is the difference in a 24T from a14T JD Baler |
Does the 24 T bale better than a 14 T. Is there much difference in the way they are built? Thanks |
| Back to top |
randy hall Long Time User
Posted: Mon Sep 24, 2012 4:08 pm Post subject: Re: What is the difference in a 24T from a14T JD Baler |
24 t is a better baler. not much is the same except for most of the knotter parts. |
| Back to top |
Tx Jim Tractor Guru
Joined: 14 Feb 1999 Posts: 13132 Location: Coyote Flats,Tx
Posted: Tue Sep 25, 2012 2:55 am Post subject: Re: What is the difference in a 24T from a14T JD Baler |
I think the bridge on the 24T plungerhead with the 2 wear pads that bolts on with one bolt was a poor design. The bolt would break and the bridge would get lost in hay field. I still remember selling them when I worked for a JD dealer. |
| Back to top |
David Snipes Guest
Posted: Tue Sep 25, 2012 10:27 am Post subject: Re: What is the difference in a 24T from a14T JD Baler |
I've run both with good results. I did break a wear pad bolt on my 24T, lost it in the field and found it weeks later. The 24T has a better method for adjusting bale length. |
| Back to top |
Dick2 Tractor Guru
Posted: Wed Sep 26, 2012 7:31 am Post subject: Re: What is the difference in a 24T from a14T JD Baler |
"10" |
| Back to top |
northvale-PA Regular
Posted: Sat Sep 29, 2012 3:32 am Post subject: Re: What is the difference in a 24T from a14T JD Baler |
go for 24T. The next model is a 336 which basically put rollers in the plunger head and gears to drive the knotters. 24T's had shaft driven kickers which hammer themselves to pieces but can be fitted with a #30 hydraulic kicker with the correct brackets. |
| Back to top |
Tx Jim Tractor Guru
Posted: Sat Sep 29, 2012 5:15 am Post subject: Re: What is the difference in a 24T from a14T JD Baler |
| northvale-PA wrote: | | (quoted from post at 07:32:01 09/29/12) 24T's had shaft driven kickers which hammer themselves to pieces |
336 & 24T share the same knotters and both are shaft driven just that 24T knotter shaft is chain driven instead of gears. |
| Back to top |
B.c.c. New User
Posted: Wed Oct 03, 2012 5:58 pm Post subject: Re: What is the difference in a 24T from a14T JD Baler |
24 T is built better per other replies. But a 14T can put up a lot of hay if you give it a chance. I had one that appeared to have been used for artillery practice, then donated to a welding school. Put up several thousand bales of grass hay with it, mostly without really understanding what I was doing. Sold it for what I'd paid for it (225) and probably could have gotten a bunch more. Wound up with a 336 and wouldn't go back. |
| Back to top |
YT Home
| Tractor Manuals
| Tractor Parts
| Forum Home
