| Author |
Message |
gracepat New User
Posted: Mon Sep 24, 2012 4:36 pm Post subject: 1949 8N engine oil pressure |
What should the engine oil pressure be on an 1949 8N Ford tractor? Help! |
| Back to top |
old Tractor Guru
Joined: 12 Mar 2000 Posts: 50467 Location: Lake of the Ozarks area of MO
Posted: Mon Sep 24, 2012 4:43 pm Post subject: Re: 1949 8N engine oil pressure |
Can be as high as 50PSI on a new rebuilt engine or as low as 5psi on and older engine. Big range of numbers but all are with in working range and the type of oil and what has or has not been done to it make a big difference |
| Back to top |
TheOldHokie Tractor Guru
Joined: 08 Apr 2005 Posts: 5874 Location: Myersville, MD
Posted: Mon Sep 24, 2012 5:23 pm Post subject: Re: 1949 8N engine oil pressure |
| gracepat wrote: | | (quoted from post at 20:36:06 09/24/12) What should the engine oil pressure be on an 1949 8N Ford tractor? Help! |
A flathead Ford engine in good shape should produce a minimum of 20 PSI hot oil pressure at idle. New from the factory it was probably 30+ PSI. At 1500 RPM you would like to see 40 PSI hot oil pressure. Pressures significantly lower than that are usually an indication of increased oil clearances due to worn bearings and/or journals.
TOH |
| Back to top |
Bill Rowles Regular
Posted: Mon Sep 24, 2012 9:35 pm Post subject: Re: 1949 8N engine oil pressure |
If it is low, check the oil pump internal parts for wear and the suction line for an air leak (loose solder joint). As long as you have it apart to do that, also check main and rod bearing clearance with plastigage or micrometers. |
| Back to top |
Bob Purinton Regular
Posted: Tue Sep 25, 2012 4:05 am Post subject: Re: 1949 8N engine oil pressure |
I noticed on my '48 8N the other night that 30 lbs. of pressure at first start went to about 12 lbs. after it warmed up. Revving the engine would get it to about 27-28 lbs. at full governed rpm's. Oil I'm using is Shell Rotella 15-40. |
| Back to top |
souNdguy Tractor Guru
Posted: Tue Sep 25, 2012 6:46 am Post subject: Re: 1949 8N engine oil pressure |
what's yer hot / cold / throttle / idle pressures and wht oil ya running.
5-6 psi hot throttle will keep metal from bumping.. but is minimums and ain't great. |
| Back to top |
Posted: Tue Sep 25, 2012 7:44 am Post subject: Re: 1949 8N engine oil pressure |
| soundguy wrote: | (quoted from post at 10:46:05 09/25/12) what's yer hot / cold / throttle / idle pressures and wht oil ya running.
Remember - it isn't pump pressure that keeps the parts separated - it's hydro-dynamic pressure created by the crankshaft journals spinning inside a close fitting bearing shell. And if the crankshaft joutrnal oil clearances are so wide that you are only getting 5 PSI pumping pressure the excessive clearance will prevent the hydro-dynamic pressure wedge (e.g. oil film) from fully forming and parts start to rub - especially at low RPM and/or under heavy loads.
TOH
| Back to top |
YT Home
| Tractor Manuals
| Tractor Parts
| Forum Home
