Tractor
 Parts
Yesterday's Tractors
Tractor Manuals
Shop for Parts:
Project Journal
Tractor Town
Show & Pull Guide
Related Sites
The Tractor Shed
TractorLinks.com
Ford N-Series Club
Garden Tractors
Today's Tractors
Classic Trucks
Kountry Life
subscribe
unsubscribe
Content Guide
Picture List - TOC
Ad Archives - TOC
Manuals - TOC
NAA Ford Tractor Problems
Post new topic    Yesterday's Tractors Forum Index -> Ford
jwhalin
PostPosted: Tue Sep 25, 2012 8:33 am    Post subject: NAA Ford Tractor Problems Reply to specific post Reply with quote
Hey can anyone help me with a Restored NAA ignition 12V Negative Ground Ignition Circuit? I have on my ignition circuit: Battery Cable to Solenoid, +DC from Solenoid to Ammeter, through the ammeter, Ammeter to Batt on Ignition switch, Under same lug on ammeter as +DC from solenoid, I have cable going to Batt on Altenator. From other side of solenoid I have cable going to starter. From small lug on solenoid, I have wire going to ST on ignition switch. Lights are hooked up on ACC on ignition Switch. #1 lug on Altenator is hooked up on IGN on ign switch. #2 on Altenator is bonded to BATT from Altenator going to one side of Ammeter. Tractor started fine ran good for 10 minutes, then died. I had installed Petronix Electronic Ignition 2 years ago. Changed Coil and tractor started and ran well. Went to turn key off and tractor would not shut off? What have I done wrong? Please Help!!
JMOR
PostPosted: Tue Sep 25, 2012 8:39 am    Post subject: Re: NAA Ford Tractor Problems Reply to specific post Reply with quote
jwhalin wrote:
(quoted from post at 12:33:35 09/25/12) Hey can anyone help me with a Restored NAA ignition 12V Negative Ground Ignition Circuit? I have on my ignition circuit: Battery Cable to Solenoid, +DC from Solenoid to Ammeter, through the ammeter, Ammeter to Batt on Ignition switch, Under same lug on ammeter as +DC from solenoid, I have cable going to Batt on Altenator. From other side of solenoid I have cable going to starter. From small lug on solenoid, I have wire going to ST on ignition switch. Lights are hooked up on ACC on ignition Switch. #1 lug on Altenator is hooked up on IGN on ign switch. #2 on Altenator is bonded to BATT from Altenator going to one side of Ammeter. Tractor started fine ran good for 10 minutes, then died. I had installed Petronix Electronic Ignition 2 years ago. Changed Coil and tractor started and ran well. Went to turn key off and tractor would not shut off? What have I done wrong? Please Help!!
What have I done wrong? This: " #1 lug on Altenator is hooked up on IGN on ign switch. " Move that wire to accessory. There are other options too.
Jeff Whalin
PostPosted: Wed Sep 26, 2012 4:16 pm    Post subject: Re: NAA Ford Tractor Problems Reply to specific post Reply with quote
Thanks for the help. That fixed my problem. Now, one more
quick thing, on my 12 volt negative ground, Do I need the
diode on the # 1 wire coming from the Altenator, if so, what
size? Also, do I need a resistor coming from coil to the
switch? If so, what size on that too. Thanks for any and all
help. My father had restored this tractor several years ago,
and he passed away 2 years ago. I did not have a lot of
experience with this tractor.
JMOR
PostPosted: Wed Sep 26, 2012 4:40 pm    Post subject: Re: NAA Ford Tractor Problems Reply to specific post Reply with quote
Jeff Whalin wrote:
(quoted from post at 20:16:55 09/26/12) Thanks for the help. That fixed my problem. Now, one more
By using the accessory position for alt #1, you can skip the diode (some will say it isn't best way, but it works).
If it has been OK for 2 years without the resistor, then it likely does not need one. Pertronix instructions say that the total coil plus any added resistance should add up to 3 Ohms.......some coils alone will be 3 or more.
jwhalin
PostPosted: Thu Sep 27, 2012 2:25 am    Post subject: Re: NAA Ford Tractor Problems Reply to specific post Reply with quote
Thanks for the info JMOR. I really appreciate the help. This Forum has been a huge help to me.
Thanks again.
