| Author |
Message |
59junior New User
Posted: Tue Sep 25, 2012 9:27 am Post subject: front wheels with loader |
I had the loader installed on the 8n and while it works great the front 3" x 16" ribbed wheels are woefully inadequate. What is the heaviest duty rim and tire I can get to help The weight up front better? I have seen 4.5" x 16" at around 2300lbs capacity. Is there something better or is that pretty much the upper limit. Thanks in advance! |
| Back to top |
wes(MI) Regular
Posted: Tue Sep 25, 2012 10:39 am Post subject: Re: front wheels with loader |
They do make make some 5.5" width wheels but unsure of their cost. I usually get old truck rims and cut the centers out and weld in ag repair centers on mine. Two repair centers are the same cost as one ag rim in my area. And junkyards are happy to get $10 out of bent/ rusty rims too. |
| Back to top |
TheOldHokie Tractor Guru
Joined: 08 Apr 2005 Posts: 5875 Location: Myersville, MD
Posted: Tue Sep 25, 2012 10:54 am Post subject: Re: front wheels with loader |
| 59junior wrote: | | (quoted from post at 13:27:45 09/25/12) I had the loader installed on the 8n and while it works great the front 3" x 16" ribbed wheels are woefully inadequate. What is the heaviest duty rim and tire I can get to help The weight up front better? I have seen 4.5" x 16" at around 2300lbs capacity. Is there something better or is that pretty much the upper limit. Thanks in advance! |
I opted for the 5.5 x 16 wheels with 5.5 x 16 3 rib fronts on my (loader-less) 8N - I like them far better than the 3 x 16 original size.
TOH
| Back to top |
souNdguy Tractor Guru
Posted: Tue Sep 25, 2012 3:09 pm Post subject: Re: front wheels with loader |
on a couple of my hevier loader tractors I got wide implement rims 16" and on one set put multi rib tires on it.. the other has used truck tires.. both work better than tri ribs.. |
| Back to top |
John in Mich Regular
Posted: Tue Sep 25, 2012 4:17 pm Post subject: Re: front wheels with loader |
My '52 8N with a Wagner loader has 6.50-16 6 ply 5 rib implement tires pumped up to 45 pounds.
Carries the weight well, still does not steer worth a darn, but it does what I need done. |
| Back to top |
russb wa Regular
Posted: Tue Sep 25, 2012 4:57 pm Post subject: Re: front wheels with loader |
I think you may have meant 3 x 19? |
| Back to top |
Colin King Tractor Expert
Posted: Tue Sep 25, 2012 6:16 pm Post subject: Re: front wheels with loader |
The '47 2N I'm working on has P235/70R15 car tires on rims welded onto the hubs. This seems to be fairly common here for Ns that were used with loaders. I'll be removing these and replacing them with 3x19 rims & tires. If you're in Central MN, you can have them.
Colin, MN |
| Back to top |
Royse Tractor Expert
Posted: Tue Sep 25, 2012 7:00 pm Post subject: Re: front wheels with loader |
2300 lbs per tire is more than the front end of an N is going to handle.
Most just use truck tires/rims for an N with a loader.
They don't sink in as bad and they steer easier.
What part of Michigan are you in?
I have a set on a parts tractor in Ionia county.
If you're close we could work something out. Email is open. |
| Back to top |
59junior New User
Posted: Wed Sep 26, 2012 3:55 am Post subject: Re: front wheels with loader |
Im in Howell and I work in lansing. Just got my loader attachment installed and really need to beef up the front end as it still has the skinny 3 inch wheels on it and my property is sandy loam. The damn bucket/loader is probably half or more of the weight that the tractor can handle but I still think it will do the small garden variety jobs I will demand of it. Hoping to be ready for snow removal as well. I would be gratefull to work a deal out. Thanks Matt. |
| Back to top |
Posted: Wed Sep 26, 2012 4:01 am Post subject: Re: front wheels with loader |
the PO welded them right to the hub??? oh man.... |
| Back to top |
Posted: Wed Sep 26, 2012 6:17 pm Post subject: Re: front wheels with loader |
I sent you an email Matt. |
| Back to top |
Posted: Wed Sep 26, 2012 6:21 pm Post subject: Re: front wheels with loader |
Yea, no kidding! A little heavy handed, don't ya think :P
Colin |
| Back to top |
Posted: Thu Sep 27, 2012 3:43 am Post subject: Re: front wheels with loader |
i guess if you have a flat you have to pull the entire hub and .. guess check the bearings while you are at it.. sheesh... never seen one that bad... |
| Back to top |
