| Author |
Message |
Jimbo's 8n Regular
Posted: Tue Sep 25, 2012 9:29 am Post subject: blocking clutch |
I have had numerous people on this sight that they block their clutch. I do not intend on using it during the winter so I will for sure have it blocked. I currently use the tractor 1-2 times a week for 8 hours. My question is, should I still block the clutch or is that enough use to not worry about it sticking. The tractor is kept in the garage, not outside. |
| Back to top |
Dell (WA) Tractor Guru
Posted: Tue Sep 25, 2012 11:18 am Post subject: Re: blocking clutch |
Jimbo.........while constant usage will usually keep yer clutch from "sticking" to the flywheel, its so eazy to make a "block" from 2x6 and use it nitely. ........Dell |
| Back to top |
36 Coupe Tractor Guru
Posted: Tue Sep 25, 2012 2:01 pm Post subject: Re: blocking clutch |
Ive had a clutch stick in June, only 3 days without rain during the month.I use a 2x4 scrap, block it 1/2 way down |
| Back to top |
souNdguy Tractor Guru
Posted: Tue Sep 25, 2012 2:53 pm Post subject: Re: blocking clutch |
ditto what the others said.
I have a few 'daily/weekly' use amchiens I donot block during the year.. but anything that's gonna set over a week I'll block a lil bit.. |
| Back to top |
old Tractor Guru
Joined: 12 Mar 2000 Posts: 50404 Location: Lake of the Ozarks area of MO
Posted: Tue Sep 25, 2012 3:08 pm Post subject: Re: blocking clutch |
When I park my 8N I block it be it 2 hours or 2 weeks before I will use it again. Learned that just because you think your going to use it in an hour that some times that hour ends up being 2 week later due to other things in life getting in the way |
| Back to top |
teddy52food Tractor Guru
Posted: Tue Sep 25, 2012 5:07 pm Post subject: Re: blocking clutch |
Why is there a problem with sticking clutches on the Fords? I have IHC H, 2 B's, 2 F12's and a Super C that don't get blocked & don't stick. Some have sat for 3 years not running. Had a IHC F20 at deer camp that sat outside for 6 years that wasn't blocked & wasn't stuck. |
| Back to top |
russb wa Regular
Posted: Tue Sep 25, 2012 5:42 pm Post subject: Re: blocking clutch |
I have never blocked my clutch and I have never had it stick. I suspect my gear oil level may be lower than others or my seals are better. It is a curious deal. |
| Back to top |
Tom N MS Tractor Guru
Posted: Tue Sep 25, 2012 5:44 pm Post subject: Re: blocking clutch |
I don't know--------Dad has had his 2N for 50 yrs or more and never a stuck clutch--had mine since 04 and no stuck clutch except when I drenched it with oil due to a bad input shaft seal..nosed it into a ditch to pull the PTO shaft--flooded the clutch housing big time--it drained and dripped for days--had to split it and replace the clutch, pressure plate, throw out bearing and input shaft seal. |
| Back to top |
HCooke Tractor Expert
Posted: Tue Sep 25, 2012 6:40 pm Post subject: Re: blocking clutch |
Easy to block the clutch down. Not so easy to unstick it. My 1999 Kubota even has a hook and eye to block down the clutch.
| Back to top |
Bob Purinton Regular
Posted: Tue Sep 25, 2012 7:39 pm Post subject: Re: blocking clutch |
won't blocking the clutch mess up the springs in the pressure plate?
I'm not arguing; just asking. |
| Back to top |
Posted: Wed Sep 26, 2012 2:18 am Post subject: Re: blocking clutch |
Its got nothing to do with oil.Metal particles in the clutch facing rust to the pressure plate or flywheel.Never say never.When you get a stuck clutch you will know it. |
| Back to top |
Posted: Wed Sep 26, 2012 2:23 am Post subject: Re: blocking clutch |
Ive read that all import tactors come with the clutch blocked down.Its not a common problem but it happens. |
| Back to top |
Posted: Wed Sep 26, 2012 4:16 am Post subject: Re: blocking clutch |
I'll defer to the engineers on this site, but from what I've read the answer is no. |
| Back to top |
Posted: Wed Sep 26, 2012 3:30 pm Post subject: Re: blocking clutch |
Wrong again..Mine had never stuck before--nosed it down in a ditch to pull the PTO shaft..Did the job--was in no hurry-had to stop and go to town for something--stayed nosed down for 2-3 hrs just because I wasn"t in ahurry and did other things in between--Got on the tractor to move it and the clutch would not disengage..It was then that I saw oil streaming out the cotter pin hole and I knew I had flooded my clutch due to a bad input shaft seal..maybe because it was old, the clutch swelled but certainly did not rust together during that time frame..so Yes I know from experience, oil soaked clutches cause them to NOT disengage.. |
| Back to top |
Posted: Wed Sep 26, 2012 4:16 pm Post subject: Re: blocking clutch |
There was no oil on the last stuck clutch I took apart.It was rusty.My clutch stuck in June when we had only 3 days with out rain,The clutch had stuck before.We had a cut down car we used to haul hay with.I had put a new clutch in the car 5 years before we cut the car down,no oil involved.The car clutch would stick until I blocked it down when it was parked.I have to say you are wrong and so will the fellows who have fixed stuck clutches. |
| Back to top |
