| Author |
Message |
mmkid Guest
Posted: Tue Sep 25, 2012 11:39 am Post subject: uts clutch |
is there any easy way to get the clutch out of the bell housing? i was told if you just pull on it itll come out, but im not having that type of luck. any thoughts? thanks |
| Back to top |
Captainhookerus Long Time User
Posted: Tue Sep 25, 2012 2:54 pm Post subject: Re: uts clutch |
Remove front nut,and grease tube if you want to save it. Put an 8 ft bar through clutch adjusting hole and behind engaging sleeve. Put as much pressure as you can on end of bar and have some hit end of clutch shaft. Caution clutch may fly out and on to the ground quickly. |
| Back to top |
LW Long Time User
Posted: Tue Sep 25, 2012 4:13 pm Post subject: Re: uts clutch |
^^^^ What he said  |
| Back to top |
Jeff Gravert Regular
Posted: Tue Sep 25, 2012 7:33 pm Post subject: Re: uts clutch |
Or you can use a puller and bust everything before Ken tells you how to do it correctly. I held the bar and had the hired man hit the last one. Scared him pretty good when it went pop and FLEW out of there. Jeff |
| Back to top |
mmmmmmmmmmmmmmmmmmmmm Guest
Posted: Wed Sep 26, 2012 8:56 am Post subject: Re: uts clutch |
Why not just leave the nut on loose and let it catch the clutchbefore it hits the ground? You will still be able to break the taper fit loose. |
| Back to top |
YT Home
| Tractor Manuals
| Tractor Parts
| Forum Home
