loader for 2750 john deere
BIGBADDEERE
PostPosted: Tue Sep 25, 2012 1:21 pm    Post subject: loader for 2750 john deere Reply to specific post Reply with quote
looking at a allied loader for my 2750 cab tractor..don't know what kind of tractor it came from..it has mounts and guy says its inter changable but he is just tring to sell it for the widow..question is its a 595 loader and is he right about it will fit my 2750..i have looked for information and can't find anything.also i know i will need to get the wobble controls for inside the cab..thanks,,bill
TractormanNC
PostPosted: Tue Sep 25, 2012 1:53 pm    Post subject: Re: loader for 2750 john deere Reply to specific post Reply with quote
Have an Allied 595 on an open station 2750. LOVE IT. It came off a 770 case. Had to make a few spacers and drill a few holes.
Biggest problem we had was finding a closed center plug to convert the valve from open center to closed center. If the loader came off a tractor with open center hyds, crank down the relief valve so it"s not always bypassing oil. Plumb it up like many posts have talked about.
If you don"t already have them, find a set of "cultivator mounts" flat steel plates about 1/2"thick by about 6" wide that connect the steering support to the clutch housing on both sides of the engine.
Tx Jim
PostPosted: Tue Sep 25, 2012 2:37 pm    Post subject: Re: loader for 2750 john deere Reply to specific post Reply with quote
As previously stated be sure control valve is closed-center type.
BIGBADDEERE
PostPosted: Tue Sep 25, 2012 4:32 pm    Post subject: Re: loader for 2750 john deere Reply to specific post Reply with quote
what do you mean by closed center type..
buickanddeere
PostPosted: Tue Sep 25, 2012 5:28 pm    Post subject: Re: loader for 2750 john deere Reply to specific post Reply with quote
An open centre valve on the closed centre Deere system will make the pump run 100% capacity all the time . Power steering and rock shaft will quit working unless the loader is lifting a heavy load.
Use a "T" from the high pressure line to supply the loader valves . Return the loader oil to a ported filter cover on Dubuque and Mannheim tractors. As txjim pointed out, the Waterloo tractors can use a T into the rockshaft return line.
Tx Jim
PostPosted: Wed Sep 26, 2012 3:05 am    Post subject: Re: loader for 2750 john deere Reply to specific post Reply with quote
BIGBADDEERE wrote:
(quoted from post at 20:32:55 09/25/12) what do you mean by closed center type..
On a closed center hyd system the oil pressure is maintained in the lines by being blocked by each hyd control valve and the hyd pump stops building pressure. When a hyd lever is moved then oil flows through hyd control valve to operate a function and immediately hyd pump starts back building pressure until the hyd valve is closed. Hence the name closed
When JD introduced closed center hyd systems at their sales meeting JD rep's claimed that a closed center hyd system saved fuel because hyd oil wasn't continuously being pumped.
In contrast on an open center the pump pumps oil constantly,oil flows through each control valve and then the required valve diverts the oil to operate required hyd function.
Tx Jim
PostPosted: Wed Sep 26, 2012 3:19 am    Post subject: Re: loader for 2750 john deere Reply to specific post Reply with quote
buickanddeere wrote:
(quoted from post at 21:28:14 09/25/12) Power steering and rock shaft will quit working unless the loader is lifting a heavy load.
B&D
Please explain how a lifting a heavy load will cause the power steering and rockshaft to operate on a closed center tractor with an open center valve?? I don't understand what a heavy load has to do with that. I could make either the PS &/or RS operate with no load on the loader but don't understand your heavy load concept. Thanks,Jim.
8850dave
PostPosted: Wed Sep 26, 2012 4:01 am    Post subject: Re: loader for 2750 john deere Reply to specific post Reply with quote
I have a JD245 loader that would bolt right on with new mounting brackets and joystick control with good bucket located in Northern Illinois.
Tx Jim
PostPosted: Wed Sep 26, 2012 4:32 am    Post subject: Re: loader for 2750 john deere Reply to specific post Reply with quote
8850dave wrote:
(quoted from post at 08:01:08 09/26/12) I have a JD245 loader that would bolt right on with new mounting brackets and joystick control with good bucket located in Northern Illinois.
A 245 is a good match for a 2750. How much $$$$ and does it have JS hyd controls??
buickanddeere
PostPosted: Wed Sep 26, 2012 6:15 am    Post subject: Re: loader for 2750 john deere Reply to specific post Reply with quote
If the loader is connected downstream of the priority valve then
yes the PS will operate.
The rock shaft won't have high pressure oil unless the
loader is restricting flow via lifting a load and increasing
pressure
Tx Jim
PostPosted: Wed Sep 26, 2012 8:32 am    Post subject: Re: loader for 2750 john deere Reply to specific post Reply with quote
(quoted from post at 10:15:09 09/26/12) If the loader is connected downstream of the priority valve then
pressure
Sorry but power steering won't operate any better than rockshaft just because of pressure control(aka priority valve) where an open center valve is involved.The only thing short of removing open center valve is operate the boom or bucket cylinders to their maximum travel and hold that control lever to block flow of oil through the OC valve. Then PS & RS should work after pump stops cavitating.
