| Author |
Message |
david1 Guest
Posted: Tue Sep 25, 2012 1:31 pm Post subject: JD 2940 PTO problems |
Today while trying to round bale the PTO stopped turning when the bale got to about 3 ft. Could this only be cause by an internal hose leak. Thanks |
| Back to top |
tim s Tractor Guru
Joined: 01 Nov 2008 Posts: 5949 Location: Somerset Ohio
Posted: Tue Sep 25, 2012 1:35 pm Post subject: Re: JD 2940 PTO problems |
Check your filter and sump screen first, if they are restricted it can cause low to no transmission pressure,,if that"s all okay then it could be a cracked oil line, or a failing transmission pump,,or a component leak ,,lets hope for a plugged filter... |
| Back to top |
Tx Jim Tractor Guru
Joined: 14 Feb 1999 Posts: 13175 Location: Coyote Flats,Tx
Posted: Tue Sep 25, 2012 2:26 pm Post subject: Re: JD 2940 PTO problems |
I agree with Tim S in always check the easiest things first such s hyd filter and sump screen. |
| Back to top |
buickanddeere Tractor Guru
Joined: 31 May 2003 Posts: 23633 Location: in front of computer
Posted: Tue Sep 25, 2012 5:41 pm Post subject: Re: JD 2940 PTO problems |
When was the last time the filter and screen were serviced?
Is there a loader or any other hydraulic loads connected to the tractor?
Has the slippage occurred suddenly or gradually?
Any difference with transmission rabbit-turtle lever in either high or low speed. |
| Back to top |
YT Home
| Tractor Manuals
| Tractor Parts
| Forum Home
