Tractor
 Parts
Yesterday's Tractors
Tractor Manuals
Shop for Parts:
Project Journal
Tractor Town
Show & Pull Guide
Related Sites
The Tractor Shed
TractorLinks.com
Ford N-Series Club
Garden Tractors
Today's Tractors
Classic Trucks
Kountry Life
subscribe
unsubscribe
Content Guide
Picture List - TOC
Ad Archives - TOC
Manuals - TOC
governor/RPM questions on a JD A
Post new topic    Yesterday's Tractors Forum Index -> Tractor Pulling
Clint Skarovsky
PostPosted: Wed Sep 26, 2012 6:58 am    Post subject: governor/RPM questions on a JD A Reply to specific post Reply with quote
Bear with me here guys, this might get long winded. I've had a '45 A with a PB for a couple of years and have been pulling it. Everything in the motor is unknown - it always pulls strong at 4600 and 5100, I've won something everytime out. It's very hard to find a happy throttle position between idle and running wide open. In fact it's never wanted to low idle well. A couple of months ago I bought a '51 A, the tractor is stock with the exception of a big nut carb. This tractor runs like it should, it will low idle all day, set the throttle and forget it, low RPM. So I swapped the big nut carb to the old tractor with a PB, at the same time I swapped to a dry air filter and G intake tube. It runs great, the problem is that any throttle movement and the engine just runs away. I definitely exacerbated the situation. I don't have a tach so I can't tell the RPM but it definitely feels like more than 1080.
As an aside, it doesn't necessarily like to rev under load, it's just a neutral/putting around thing.
Any thoughts? Thanks
a1940jd
PostPosted: Wed Sep 26, 2012 2:42 pm    Post subject: Re: governor/RPM questions on a JD A Reply to specific post Reply with quote
if the length of the throttle linkage between the govenor arm and the carburator is not exactly correct the govener is rendered practically useless. It sounds as if you know for sure your govenor is working. If so its most likely only a linkage issue due to the pb and possible an aftermarket manifold changing the distance between the carburator and the govenor arm from its factory length. Check your IT manual for a clear explanation.
Little Big B
PostPosted: Wed Sep 26, 2012 10:20 pm    Post subject: Re: governor/RPM questions on a JD A Reply to specific post Reply with quote
clint skarovsky wrote:
(quoted from post at 15:58:51 09/26/12) Bear with me here guys, this might get long winded. I've had a '45 A with a PB for a couple of years and have been pulling it. Everything in the motor is unknown - it always pulls strong at 4600 and 5100, I've won something everytime out. It's very hard to find a happy throttle position between idle and running wide open. In fact it's never wanted to low idle well. A couple of months ago I bought a '51 A, the tractor is stock with the exception of a big nut carb. This tractor runs like it should, it will low idle all day, set the throttle and forget it, low RPM. So I swapped the big nut carb to the old tractor with a PB, at the same time I swapped to a dry air filter and G intake tube. It runs great, the problem is that any throttle movement and the engine just runs away. I definitely exacerbated the situation. I don't have a tach so I can't tell the RPM but it definitely feels like more than 1080.
With the throttle lever all the way forward and the butterfly in the carb all the way open. Your throttle rod should be a quarter of a hole, roughly, too short. Shorten rod to make the governor more sensitive and lengthen it to calm it down. It takes a little fine tuning to get it perfect but its not too bad to do.
If that doesnt solve your problem, you'll have to pull the gov shaft out and inspect weight pin holes, weight pins, the throw out arm, the throw out bearing, and make sure the throw out bearing sleeve slides freely on the shaft.
Good luck!
Derek Holdren
View user's profile MSN Messenger
Earl-IL
PostPosted: Thu Sep 27, 2012 7:57 pm    Post subject: Re: governor/RPM questions on a JD A Reply to specific post Reply with quote
Replies are good,but make sure the cotter key at the carb. isn't dragging.
Post new topic    Yesterday's Tractors Forum Index -> Tractor Pulling All times are GMT - 8 Hours
