| Author |
Message |
kylemorley Regular
Posted: Wed Sep 26, 2012 7:56 am Post subject: Anyone know what urethane modified alkyd is? |
I am getting ready to paint a rusting and peeling 8n using the lye and pressure washer method rather than full strip followed by brush and rattle can.
I was going to use Rustoleum, but while at the hardware store noticed they have a "urethane modified alkyd enamel" for a little more money. I know alkyds have a reputation for fading quickly, but just about every reasonably cheap paint I can find - Rusto, TSC, NH and Zero Rust - suitable for what I am trying to do (as opposed to expensive automotive paints) turns out, on careful reading of the label, to be some sort of alkyd.
Anyone know what "urethane modified alkyd is? Any suggestions on other paints that might be a better bet than Rusto? |
| Back to top |
CNKS Tractor Guru
Posted: Wed Sep 26, 2012 4:16 pm Post subject: Re: Anyone know what urethane modified alkyd is? |
Urethane may be the wrong term, but the company should know what they have. There is a product called acrylic modified alkyd enamel, which is the old alkyd enamel with acrylic properties, one of which is UV inhibitors to slow fading. Some or all of the tractor manufacturers sell this product, along with some of the paint companies. It is not as good as urethane, but considerably better than straight alkyd enamel. You might check with your New Holland dealer and see if they know what paint they sell. CaseIH used to use the term acrylic modified on the can, not anymore, far as I know. JD and NH are likely the same. My guess is that is what Rustoleum is selling -- I would trust the dealers paint more than Rustoleum -- probably made by Valspar, they may make the Rustoleum version too. |
| Back to top |
kylemorley Regular
Posted: Thu Sep 27, 2012 6:49 am Post subject: Re: Anyone know what urethane modified alkyd is? |
Best I can figure out, it is possible to make a alkyd that has been spiked with another, tougher, resin - most often (for car and tractor paint) acrylic, but urethane can also be used. This seems to create a hybrid which falls somewhere between the tractor and utility alkyds and the expensive two part automotive finishes in performance. Better resistance to fading is one of the advantages often mentioned.
This would seem to be a useful thing, then, for those of us who are not trying to do a show finish, but rather just get some paint on a working tractor, to keep it from rusting away. But how good they are probably depends on how much urethane they are using - like the pancake syrup blends you buy in the supermarket that have 0.5% real maple syrup! |
| Back to top |
glennster Tractor Guru
Posted: Thu Sep 27, 2012 7:25 am Post subject: Re: Anyone know what urethane modified alkyd is? |
here ya go, it is a high performance industrial coating.
Industrial Urethane Alkyd
Industrial Urethane Alkyd Enamel is a high solids, high gloss, 2.8 lb/gal VOC compliant coating intended for interior/exterior use in industrial environments. It is easy to brush, roll or spray. Provides performance comparable to Silicone Alkyds
Modified with urethane resin for increased durability and ease of application
Resistant to chipping and flaking
Resists yellowing
Abrasion resistant
Appropriate for interior and exterior applications
Good gloss and color retention
Recommended Usage
For use over properly prepared substrates in industrial environment. Appropriate applications include:
Steel stairs and walls
Structural and miscellaneous steel
Machinery and equipment
Handrails
Safety and pipe marking
Pipe racks
Conforms to AWWA D102-03 OCS #1
For longer lasting aesthetic performance, topcoat with Sher- Clear 1K Acrylic Clear Coat
Suitable for use in USDA inspected facilities
Acceptable for use in high performance architectural applications. |
| Back to top |
YT Home
| Tractor Manuals
| Tractor Parts
| Forum Home
