400 shifter problem UPDATE
donwisc
PostPosted: Wed Sep 26, 2012 10:15 am    Post subject: 400 shifter problem UPDATE Reply to specific post Reply with quote
This is a follow up to a previous post a couple days ago.
My buddy took off the shift lever and tower and did not find any obvious wear BUT the bottom 2 to 3 inches of the shaft is bent about 10 degrees in relation to flat portion of the shaft.
He is now in the process of straightening the shaft and putting back together. Will ad vise the results.
John Saeli
PostPosted: Wed Sep 26, 2012 4:59 pm    Post subject: Re: 400 shifter problem UPDATE Reply to specific post Reply with quote
Bent shifter. That's because they grab the shifter with a tight fist, instead of a loose palm. Take your time, & let it "find itself".
