| Author |
Message |
Blindhawg Regular
Posted: Wed Sep 26, 2012 3:44 pm Post subject: 5 speed shifter |
Is this a common issue w/5 sp shifter? Woodruff keyway
wallowed out in top of shifter shaft. I can"t figure how to get it
out of transmission w/out complete dissasembly. For 2 cents
I"d weld the shift lever to the shaft and let the next owner worry
about it!!! |
| Back to top |
Hobo,NC Tractor Guru
Joined: 14 Jun 2007 Posts: 10611 Location: Sanford, NC
Posted: Wed Sep 26, 2012 4:12 pm Post subject: Re: 5 speed shifter |
| Blindhawg wrote: | (quoted from post at 03:44:26 09/27/12) Is this a common issue w/5 sp shifter? Woodruff keyway
about it!!! |
Only after it reaches 60 years old... Trans will have to come apart That equals more worn parts to replace that you do not want to here about...
| Back to top |
Blindhawg Regular
Posted: Wed Sep 26, 2012 5:03 pm Post subject: Re: 5 speed shifter |
Was going to replace perfectly good 4 spd to get the granny
gear of the 5 spd. In your opinion, would it be worth it for bush
hoggin, discing and plowing with a 600? |
| Back to top |
Dean Tractor Guru
Posted: Wed Sep 26, 2012 5:12 pm Post subject: Re: 5 speed shifter |
The lower first gear of the 5 speed is helpful for certain tasks but not slow enough for a roto-tiller.
More importantly, if the 5 speed is from a x6x tractor, and you swap in all of the associated parts you will gain live PTO.
Dean |
| Back to top |
DenisW Regular
Posted: Wed Sep 26, 2012 6:51 pm Post subject: Re: 5 speed shifter |
My 5 speed was frozen. Got it freed up with 50-50 atf and acetone mixed in oil can so I could apply directly to rust spots. Drained old oil, put in 8 quarts diesel, magnet in the drain plug, drove around ranch for a bit to warm it up. Drained diesel and found woodruff key on magnet. Refiled with 80-90 gear oil.
DenisW |
| Back to top |
Brian in MA Tractor Expert
Posted: Thu Sep 27, 2012 8:05 am Post subject: Re: 5 speed shifter |
I'm not familiar with that tranny, but I second your opinion if you are serious and it can work, weld it and keep using it. Had a similar issue with a shift fork on a 2120 Ford tractor. I covered what I could with wet rags and welded the shift fork inside the tranny. That was 12 years ago and it is still working fine. It would have been a double split to replace it, didn t seem worth the hassle. Weld can be ground if it needs to come apart later. |
| Back to top |
Keith Williams Long Time User
Posted: Fri Sep 28, 2012 7:29 am Post subject: Re: 5 speed shifter |
Blindhawg,
People used to Braze stuff like that in the past?
Would that work here??
HTH
Keith |
| Back to top |
YT Home
| Tractor Manuals
| Tractor Parts
| Forum Home
