Tractor
 Parts
Yesterday's Tractors
Tractor Manuals
Shop for Parts:
Project Journal
Tractor Town
Show & Pull Guide
Related Sites
The Tractor Shed
TractorLinks.com
Ford N-Series Club
Garden Tractors
Today's Tractors
Classic Trucks
Kountry Life
subscribe
unsubscribe
Content Guide
Picture List - TOC
Ad Archives - TOC
Manuals - TOC
John deere 350 mower
Post new topic    Yesterday's Tractors Forum Index -> Implement Alley
jdman(MO)
PostPosted: Wed Sep 26, 2012 6:38 pm    Post subject: John deere 350 mower Reply to specific post Reply with quote
I have some questions about lubrication. In previous post, pictures show grease fittings for the wobble box including a secret fitting. Neither looking at the manual or inspection, can I find these 3 fittings. If they exist how do you get to them. It is stated that lubrication of this item is very important. help ....Russ
James Howell
PostPosted: Thu Sep 27, 2012 4:39 am    Post subject: Re: John deere 350 mower Reply to specific post Reply with quote
Take a look about halfway down on page 32 of your operator's manual.
The manual displays the three grease fittings and recommends lubrication every 10 hours.
The photos below show all three of these fittings.
Photobucket
Photobucket
The grease fitting on the top is for the two cone bearings in the crank housing.
You might need to rotate the flywheel until it can be reached.
The grease fittings in the middle and on the bottom are for the rear drive head pivot cone bearings.
On the bottom of page 32 the grease fitting for the crank/drive yoke bearing is displayed and recommends lubrication every 10 hours.
The photo below shows the location of the hidden, "secrete" grease fitting for the crank/drive yoke bearing.
Photobucket
Hope this helps.
jdman(MO)
PostPosted: Thu Sep 27, 2012 6:48 am    Post subject: Re: John deere 350 mower Reply to specific post Reply with quote
Thanks, this my new mower, replacing a #5. So the zerks shown on pic 1 and 2 are the same ones, I was thinking their was 3 on the bottom. The other issue is the end of the sickle is about 1/8 inch above the bar and is riding hard on the ledger plate. It looks like I need more shims. Also would a double knife be installed on the end be a good idea. Russ
James Howell
PostPosted: Thu Sep 27, 2012 8:13 am    Post subject: Re: John deere 350 mower Reply to specific post Reply with quote
Installing an end "section-and-a-half" on the end of the knife is a very good idea.
IMG_1424-Copy
It will help eliminate any grass clogs at the outer shoe.
You will need to remove the knife hold-down clip on the end of the cutter bar.
Photobucket
Remove the old knife section.
Photobucket
Photobucket
IMG_3395-Copy
Remove the outer shoe and shims.
Photobucket
Install the rivets or nuts and screws on the end section.
IMG_3396-Copy
IMG_3397-Copy
IMG_1425-Copy
Replace the outer shoe and shims.
Photobucket
There are three sizes of shims: .007, .020, and .030.
Suggest using a couple of the .020 and .030 shims as necessary.
Use lock nuts on the plow bolts that secure the outer shoe.
Be sure to check the clearance on the stripper and new end section.
Photobucket
Hope this helps.
jdman(MO)
PostPosted: Thu Sep 27, 2012 9:44 am    Post subject: Re: John deere 350 mower Reply to specific post Reply with quote
Thanks again, really nice pictures..Russ
Post new topic    Yesterday's Tractors Forum Index -> Implement Alley All times are GMT - 8 Hours
