| Author |
Message |
engel kupers New User
Posted: Wed Sep 26, 2012 9:49 pm Post subject: linkbelt 3400 excavator |
the tracks on my excavator are all seized up from not using enough whats the best way to get them loose again any suggestions |
| Back to top |
NCWayne Tractor Expert
Posted: Thu Sep 27, 2012 6:33 am Post subject: Re: linkbelt 3400 excavator |
About the only way to try, and there are no guarantees, is to keep them soaked in penetrating oil, diesel fuel, etc. Then walk it and hope everything breaks free. The biggest thing determining how easily they free up is how worn the tracks are. The more worn the easier they will free up, but the newer and less worn they are, the worse they will be to get freed up.
Got one customer with an old IH track loader in the same shape. In his case the undercarriage was nearly new when he got it, but it had just sat for quite a few years. What I mentioned above is we did to his and we got about 50% of the tightness out of them within a few weeks. The rest all we can do is hope they free up with use. Good luck. |
| Back to top |
jm. Tractor Expert
Posted: Thu Sep 27, 2012 2:56 pm Post subject: Re: linkbelt 3400 excavator |
Wayne is about right. Had a customer that parked is track loader in the pond for about two years because his tracks kept getting stuck and stiff. If you can ever get the excvator moving 10 inches back and forth, you may can work the stiff links into moving but will be hard. Soak in anything you have got to pour on them. |
| Back to top |
AJ. Long Time User
Posted: Fri Sep 28, 2012 4:03 pm Post subject: Re: linkbelt 3400 excavator |
I had good success using the high pressure hot washer,labor intensive but works,blast away at the pin/bush joints from both sides and it gets rid of the rust,once you get it to move rocking to and fro you will soon have them free,tale it easy as you have the track motors and finals under great strain, have the 14 pounder at hand to knock down any that bunch up.
Good luck
AJ |
| Back to top |
YT Home
| Tractor Manuals
| Tractor Parts
| Forum Home
