Tractor
 Parts
Yesterday's Tractors
Tractor Manuals
Shop for Parts:
Project Journal
Tractor Town
Show & Pull Guide
Related Sites
The Tractor Shed
TractorLinks.com
Ford N-Series Club
Garden Tractors
Today's Tractors
Classic Trucks
Kountry Life
subscribe
unsubscribe
Content Guide
Picture List - TOC
Ad Archives - TOC
Manuals - TOC
4020 LOAD CONTROL SHAFT BUSHING removal
Post new topic    Yesterday's Tractors Forum Index -> John Deere
ridgelane
PostPosted: Thu Sep 27, 2012 8:34 am    Post subject: 4020 LOAD CONTROL SHAFT BUSHING removal Reply to specific post Reply with quote
What is the easiest way to remove the load control shaft bushings on a JD 4020?
Every year without fail, one side will suddenly start leaking oil. The bushing on that side doesn't appear to have much wear but I'm at wits end as to why its always the same side and why the seal holds about a year then starts dripping constantly. I figure I might as well bite the bullet and replace the bushings and seals. Shaft is good.
David G
PostPosted: Thu Sep 27, 2012 8:55 am    Post subject: Re: 4020 LOAD CONTROL SHAFT BUSHING removal Reply to specific post Reply with quote
Shaft is either bad or too much endplay or both.
David G
PostPosted: Thu Sep 27, 2012 8:56 am    Post subject: Re: 4020 LOAD CONTROL SHAFT BUSHING removal Reply to specific post Reply with quote
I will add, replace shaft, bushings, seals and shim end play.
Mike M
PostPosted: Thu Sep 27, 2012 9:01 am    Post subject: Re: 4020 LOAD CONTROL SHAFT BUSHING removal Reply to specific post Reply with quote
Replace it all at the same time & do the bushings in the drawbar yoke and get the aftermarket ones for in the tractor that have an o-ring in them.
tim s
PostPosted: Thu Sep 27, 2012 9:18 am    Post subject: Re: 4020 LOAD CONTROL SHAFT BUSHING removal Reply to specific post Reply with quote
Yes too much side to side end play is what kills them, Deere offers shims to take that out. As the hitch bangs back and forth it continually wears on the seals till they fail..
pete 23
PostPosted: Thu Sep 27, 2012 9:49 am    Post subject: Re: 4020 LOAD CONTROL SHAFT BUSHING removal Reply to specific post Reply with quote
How often do you use draft control. If never, take those bushings to a machine shop. Have them make you some with a straight center hole,(no taper), install them and then throw those originals in the junk. Not one of Deere's better ideas. I replaced a lot of busings, seals and shafts in just four years of working at at Deere dealer. I never was able to go with my idea as of course everyone wanted it like it was originally. IH tractors are no better, as they wear out those expensive splined shafts and connections and no one ever uses draft control anyway.
tim s
PostPosted: Thu Sep 27, 2012 9:59 am    Post subject: Re: 4020 LOAD CONTROL SHAFT BUSHING removal Reply to specific post Reply with quote
That"s right Pete, load control was made for mole board plowing,,which has become a thing of the past...
Tx Jim
PostPosted: Thu Sep 27, 2012 10:28 am    Post subject: Re: 4020 LOAD CONTROL SHAFT BUSHING removal Reply to specific post Reply with quote
Tim S wrote:
(quoted from post at 13:59:33 09/27/12) That"s right Pete, load control was made for mole board plowing,,which has become a thing of the past...
Tim I beg to differ. A working L/D control will work on any 3pt plow such as a chisel plow or field cultivator.
ridgelane
PostPosted: Thu Sep 27, 2012 9:01 pm    Post subject: Re: 4020 LOAD CONTROL SHAFT BUSHING removal Reply to specific post Reply with quote
Thanks for the comments. One question remains unanswered, how do I get the bushings out?
Tx Jim
PostPosted: Fri Sep 28, 2012 3:22 am    Post subject: Re: 4020 LOAD CONTROL SHAFT BUSHING removal Reply to specific post Reply with quote
Take a rod that is little smaller in diameter than the L/D shaft that is about as long,put in the bushing on one side and drive the bushing out on the other side,
DONMYEIL
PostPosted: Fri Sep 28, 2012 10:50 am    Post subject: Re: 4020 LOAD CONTROL SHAFT BUSHING removal Reply to specific post Reply with quote
Put it all in, shaft, bushings,bushings in the yoke ,(make sure the taper is in the right way ) and seals, or do it again. The shaft may look good but if its a year old replace it. Set side play as tight as it can be and still move. Just a side note if the shaft is put back in oposite of the way it came out they can break , so ive heard.
cannonball
PostPosted: Sun Sep 30, 2012 7:45 am    Post subject: Re: 4020 LOAD CONTROL SHAFT BUSHING removal Reply to specific post Reply with quote
replace with
Untitled URL Link
