| Author |
Message |
jon f mn Tractor Expert
Posted: Thu Sep 27, 2012 10:39 am Post subject: picking corn pics. |
Some pics of picking corn with th 400 and 426 picker and Jeff's NI superpicker. The NI works great, the case not so much. Had a lot of problems with that. Did get some excelent bonding time with my friend tho while fixing it. I think Jeff has less tollerance for repairs than me. LOL. Will post some videos later.
| Back to top |
Case Nutty 1660 Tractor Guru
Posted: Thu Sep 27, 2012 11:39 am Post subject: Re: picking corn pics. |
great pics jon!! bet it was a fun day even with the repairs,, what was giving you fits?? I have never picked corn before but it would seem the mounted picker would be easier to stay lined up with the rows?? but I think the pull type would be less noise and dirty?? be real neat to have seen them in the field working this is the next best thing cnt |
| Back to top |
Posted: Thu Sep 27, 2012 11:50 am Post subject: Re: picking corn pics. |
I put new chains in the elevators that take the corn from the snappers to the husking bed above the rear tires. For some reason after the new chains were installed the would catch on a thin metal guide where they come around the bottom gear. I can't figure out why tho. Tried to bend the guide up, then down, tightened the chains then loosened them, ran the picker faster then slower. Nothing seemed to make any difference. Sometimes it would run for a while, then they would catch every couple of minutes. It would catch on one side for a while then move to the other side. It was so random I just couldn't trace it to a source. I'm wondering if it was because of the paint in the chains not letting them flex properly. They are the flat type chains like a hay elevator or manure spreader apron. Will try oiling them up and see if that helps. |
| Back to top |
Jeremy McNary Regular
Posted: Thu Sep 27, 2012 2:06 pm Post subject: Re: picking corn pics. |
Looks like some pretty nice corn, around us very little of the corn made it over knee high before it burnt up this year. |
| Back to top |
55 50 Ron Long Time User
Posted: Thu Sep 27, 2012 2:34 pm Post subject: Re: picking corn pics. |
Jon,
Where in MN? I'm near Waseca. I volunteer at the MAIC Farmamerica (WWW.farmamerica.org) and they have a NI picker just like the one in your photos.
Nice photos. Thanks for posting them.
Ron |
| Back to top |
Posted: Thu Sep 27, 2012 2:40 pm Post subject: Re: picking corn pics. |
Up by Pine City. |
| Back to top |
casecollectorsc Long Time User
Posted: Thu Sep 27, 2012 3:10 pm Post subject: Re: picking corn pics. |
Great pictures and great looking corn! Our corn, not so much so. Now you make me want to get our 425 mounted on the 730. I'll have my son post pictures of the DC and IM picker later. |
| Back to top |
dbock Regular
Posted: Thu Sep 27, 2012 4:43 pm Post subject: Re: picking corn pics. |
Nice pictures. It's neat seeing one of these running. |
| Back to top |
kwoodrum570 Guest
Posted: Thu Sep 27, 2012 5:31 pm Post subject: Re: picking corn pics. |
My dad had a 426 picker on a 830 nice pictures |
| Back to top |
Posted: Thu Sep 27, 2012 5:44 pm Post subject: Re: picking corn pics. |
Not much different as far as lining up the rows. If it's muddy (it usually is here) the pull type will pull to the side and run down the corn, but with the mounted the narrow front will sink or push mud so you are stuck either way. And they are dusty and noisy. I wouldn't want to run one for a living, I just did it for fun. LOl. |
| Back to top |
770guy Regular
Posted: Thu Sep 27, 2012 5:50 pm Post subject: Re: picking corn pics. |
Is there something wrong with the gear? Maybe its loose and not running true or its worn badly? |
| Back to top |
Posted: Thu Sep 27, 2012 6:19 pm Post subject: Re: picking corn pics. |
No, gears are fine. Had no trouble til I put in new chains. The elevator kinda curves up, like an upside down rainbow and it has a guide that holds the chain down. The top of the links thats open catches on the begining of this guide. Tried to cut a bit off one guide thinking the chain would have more time to lay flat so it wouldn't catch, but that was no help. So I welded a piece back in that was a bit longer thinking it would hold the chain down sooner, but that also was no help. Kinda loosin my mind on this one. |
| Back to top |
Agri King Long Time User
Posted: Thu Sep 27, 2012 6:32 pm Post subject: Re: picking corn pics. |
I really like your Case picker set up. Hope you get the bugs worked out. Does the 400 steer hard with the picker on it? |
| Back to top |
DKase Tractor Expert
Posted: Thu Sep 27, 2012 6:37 pm Post subject: Re: picking corn pics. |
Chain in backwards? When I had that trouble with the cross conveyer on the feeder wagon I welded a 1/2" rod across the end of the guide and that solved the problem. |
| Back to top |
4x4stude Regular
Posted: Thu Sep 27, 2012 8:30 pm Post subject: Re: picking corn pics. |
I love the pictures! Thanks for sharing them. I wish I had some work for my Case tractors. They are just ornaments most of the time. |
| Back to top |
