| Author |
Message |
BigTone Regular
Posted: Thu Sep 27, 2012 11:15 am Post subject: Farmall M wireing |
Im re-wiring the tractor and as I look at farmallbobs diagrams it has three wires hooked to the fuse (regulator L to fuse, fuse to light switch, and ignition switch to fuse) but there is only 2 connectors, what am I missing? (im using a 2 wire key ignition if it matters, not the original push/pull switch).
My other question is, I have a 12 volt generator, are the A and F terminals on the gen. the same for 6 volt as they are for 12? (the top screw on the gen. has a black washer and the bottem screw has a red washer, ground and hot?)
thanks for the help guys, ~Anthony |
| Back to top |
John T Tractor Guru
Posted: Thu Sep 27, 2012 11:49 am Post subject: Re: Farmall M wireing |
My friends Bob M and Janicholson can better help with that switch, they have pictures n wiring diagrams etc. I cant pack water to them when it comes to switch details etc., but Im knee deep in theory lol
On the Genny if not marked A (Armature) and F or FLD (Field) often the ARM is the larger of the 2 posts.
If you had an ohmeter with decent accuracy on the low Rx1 ohms scale, the post with the highest resistance to the frame ground would be F and the other (A)RM. The ARM sill be very low ohms to frame while the F would be maybe 3 to 4 ohms more.
Thats the best I can do
Ol John T and all |
| Back to top |
The Red Tractor Guru
Posted: Thu Sep 27, 2012 12:44 pm Post subject: Re: Farmall M wireing |
Anthony if that is a Delco generator converted to 12 volts (I had several converted through the years) one post should have a letter stamping of A next to it in the housing and the other of F for field which is the ground side. Should be the same configuration from 6 to 12 volts. At least that is what I found on the 2 Hs and 2 Ms I converted. |
| Back to top |
DC Snider Regular
Joined: 02 Jan 2008 Posts: 72 Location: Princeton, West Virginia
Posted: Fri Sep 28, 2012 5:01 am Post subject: Re: Farmall M wireing |
You can connect to the male spade on the fuse holder with a "double barrel" female spade connector, or use a single that is for slightly larger wire, No. 10AWG or so. Hope that helps... |
| Back to top |
JMOR Tractor Guru
Posted: Fri Sep 28, 2012 5:21 am Post subject: Re: Farmall M wireing |
| BigTone wrote: | (quoted from post at 15:15:20 09/27/12) Im re-wiring the tractor and as I look at farmallbobs diagrams it has three wires hooked to the fuse (regulator L to fuse, fuse to light switch, and ignition switch to fuse) but there is only 2 connectors, what am I missing? (im using a 2 wire key ignition if it matters, not the original push/pull switch).
thanks for the help guys, ~Anthony | Try this:
http://ytforums.ytmag.com/viewtopic.php?t=945297 |
| Back to top |
YT Home
| Tractor Manuals
| Tractor Parts
| Forum Home
