| Author |
Message |
usedtobe D13 Guest
Posted: Thu Sep 27, 2012 3:53 pm Post subject: D14 in J-yard- most likely failure? |
Saw a D14 gas in the j-yard. Tractor seemed complete. Any idea what the most common failure would be? Was thinking it's be nice to have a little bit bigger than the 'B'.
Will that block bolt into my 'B'? DickL has been too inspiring... |
| Back to top |
DiyDave Tractor Guru
Posted: Thu Sep 27, 2012 4:53 pm Post subject: Re: D14 in J-yard- most likely failure? |
Check 3rd gear for popping out, the PD clutch for operation, but both need the motor running to test. |
| Back to top |
wolfman Tractor Expert
Posted: Thu Sep 27, 2012 4:55 pm Post subject: Re: D14 in J-yard- most likely failure? |
First thing to go was the block. Drain cock was not in an obvious to get to locale, plus there was not a lot of metal between the cylinders (maybe a bored out smaller engine). Often cracks between cylinders. |
| Back to top |
BushogPapa Tractor Guru
Posted: Fri Sep 28, 2012 7:58 am Post subject: Re: D14 in J-yard- most likely failure? |
Any cracks between the lower webs are not a "Death Sentence" for the AC Blocks..
They can be "Pinned", or resistance-welded to like NEW condition..
Both of our WD-45 tractors were Resistance-Welded and "Pinned" at "Columbus Col-Weld" in Cols, Ohio..
Guaranteed not to crack again..
It is amazing what some people Scrap..it may be a perfectly fine, running tractor..
Ron.. |
| Back to top |
YT Home
| Tractor Manuals
| Tractor Parts
| Forum Home
