| Author |
Message |
rick1950 Guest
Posted: Thu Sep 27, 2012 5:10 pm Post subject: 530 jd baler |
can buy a jd 530hay baler rolls and 9ft cutter and vemer V rake all in good condition is it worth $9000.00 new to haying thank you for any help is 530 baler any good. |
| Back to top |
JDseller Tractor Guru
Joined: 09 Jul 2010 Posts: 4483 Location: North-East Iowa
Posted: Thu Sep 27, 2012 5:30 pm Post subject: Re: 530 jd baler |
It would depend on the condition of everything. Also what brand, model and type of" hay cutter". That could be a $250 sickle mower or a $7500 mower conditioner. Also what type of V rake. The gall wing type are cheaper than the frame type. Then the JD 530 baler could be worth $1500-6000 depending on its condition.
So we need some more information and a few pictures would really help. Be more than glad to help just need more info. Also model numbers and serial number would really help on the baler and "hay mower". |
| Back to top |
rick1950 Guest
Posted: Thu Sep 27, 2012 6:41 pm Post subject: Re: 530 jd baler |
i was told the baler was a mid 90 modle the front hay pickup has less than 150 rolls on total rebuild rake is a veemer the cutter is 9ft. rotery type with all new blades dont know brand thank you for your help. |
| Back to top |
Posted: Thu Sep 27, 2012 7:17 pm Post subject: Re: 530 jd baler |
Rick the JD 530 baler would be no newer than a 1989 model The 535s came out in 1990. This is from memory but it will be within a year either way. The JD 530 baler was a good baler but it was twine only. That holds the value down. Also the condition of the belts and splices is just as important as the pickup. A new set of belts can cost you 2-3K depending on what type you get. Also the condition of the rolls and bearings should be checked.
I just remembered. Look at the sprockets and drive chains on the baler. If the sprockets are worn to points then they will need replaced down the road. All the sprockets and chains will run in the $1000-1500 range.
The rake being a Vermeer still make it kind of a wild guess because they make several type as well.
The mower is more than likely a arm type of disk mower. So that would be fine in grass type hay but not the best if you have clover or alfalfa. They need conditioned.
So If we put the baler at $3500-4000
The rake at $2000-2500
the mower at $2500-3000
So that would but you in the $8000-9500 for the package. So the $9000 asking price is in the market but not a real steal unless something is way more valuable than we can tell from the limited information.
So if you need/want a complete set of hay equipment then it may be a good deal. Just remember that livestock equipment is going to be cheaper in the next few months or years. The high feed costs are really pushing down the value of any of the livestock equipment. I have not even traded in a baler for the last year or so because of this. I have seen real good JD 566 round balers with mesh not break 10K. The cheaper stuff is holding up a little better but even it is sliding. I am seeing dolly wheel NH bar rakes not break $1000. They where bringing $1500-2500 just a few years ago.
So look all of the stuff over to see its actual condition. Also don't blindly take the sellers word on the age/value of the equipment. They already have it five years newer than it could be. That "total rebuild" it a real vague term too. They could just have put pickup teeth in the pickup and called that a total rebuild. Try to get them to give you a copy of the work order.
The reason I am wanting you to be real cautious it that good hay tools can be found worth the money right now. The market is real soft. The package they are offering is a fair amount of money to be spending and not getting pretty high quality equipment. $9000 will go a long ways right now and over the winter toward hay equipment.
I am not saying the package is not good but it is in the higher end of the range. So it needs to all be in good shape.
I wish I could see some pictures and models/brands/serial numbers to be able to give you a better appraisal. |
| Back to top |
Old Bob Regular
Posted: Thu Sep 27, 2012 7:52 pm Post subject: Re: 530 jd baler |
The 530 baler is a good one. Wore 2 of them out, but baled a whole bunch of hay. Simple to work on and make a good bale. Don't know about value until you see the machinery. |
| Back to top |
Tx Jim Tractor Guru
Joined: 14 Feb 1999 Posts: 13145 Location: Coyote Flats,Tx
Posted: Fri Sep 28, 2012 3:03 am Post subject: Re: 530 jd baler |
Rick
JDseller gave you some very good information and IIRC the dates(mid 80's to late 80's) for 530 is correct. Look for excessive wear in bale chamber side sheets. I've seen some very high bale numbers balers that one could almost read a newspaper through the holes. |
| Back to top |
rick1950 Guest
Posted: Fri Sep 28, 2012 4:34 am Post subject: Re: 530 jd baler |
thank all of you for your very good information . i will try to get more information i know now what to look for .again thank all of you very much. |
| Back to top |
David1 Guest
Posted: Fri Sep 28, 2012 5:25 am Post subject: Re: 530 jd baler |
Hey there JD seller, just wondering what part of the country you are in where equipment is soft? i am in the Mid Atlantic region and good stuff is pretty high because new is so expensive. Thanks |
| Back to top |
Posted: Fri Sep 28, 2012 5:06 pm Post subject: Re: 530 jd baler |
I am in North-east Iowa. Good equipment is still bringing good money here too. The only exception to this is hay tools. There has been a lot of hay ground switched to grain crops with the high prices. Then you add those same high grain prices into the feed cost and you have livestock farmers with not much profit to buy things.
It is the mid range equipment that is softest. The real later model new stuff will bring good because the guy will pick it up to save the money verses a new purchase. The cheap stuff is still high because the weekend/part time guys keep that market up. It is the $3000-15000 stuff that is soft. It is older than the new buyers want and still too high for most of the part time guys. |
| Back to top |
YT Home
| Tractor Manuals
| Tractor Parts
| Forum Home
