| Author |
Message |
GeoMo Regular
Posted: Thu Sep 27, 2012 6:26 pm Post subject: 1256 slow 3pt when cold |
My sun"s tractor. He has to run for 1/2 hour or more to get 3pt to work in winter. We are working on some leaks (in the seat lift and remote valve) is their anything to do? Thank You |
| Back to top |
wisbaker Tractor Expert
Posted: Thu Sep 27, 2012 7:52 pm Post subject: Re: 1256 slow 3pt when cold |
When was the last time the fluid was changed? Farmer I worked for in High School had an 806 that didn't steer, stop or lift very wellfor a while if it was cold, always thought it was water intheHY-Tran oil ans it was a little stiff when we tried waking it up. Are you using the correct fluid? If it's to thick she'll be stiff until you get her warmed up. |
| Back to top |
the tractor vet Tractor Guru
Posted: Fri Sep 28, 2012 4:15 pm Post subject: Re: 1256 slow 3pt when cold |
Change the oil and filter and als keep up on the filter change . When the oil is cold things don't move well . Heck i don't move well when it gets cold out i am still till i warm up. |
| Back to top |
DeltaRed Tractor Guru
Joined: 25 Feb 2010 Posts: 6545 Location: Delta,colorado
Posted: Fri Sep 28, 2012 4:39 pm Post subject: Re: 1256 slow 3pt when cold |
My 1256 is also slow to fall when its cold at start up.Sometimes it is even slow in hot weather.My 706 falls well no matter what temp,hot or cold. |
| Back to top |
pete 23 Tractor Expert
Posted: Fri Sep 28, 2012 7:06 pm Post subject: Re: 1256 slow 3pt when cold |
I would pull the unloading valve clean and polish it and new o-rings. If hitch won't raise right away when lever is pulled, try dead heading one of the aux valves. If the hitch responds to this, then you know unloading valve is problem area. |
| Back to top |
GeoMo Regular
Posted: Sat Sep 29, 2012 7:22 pm Post subject: Re: 1256 slow 3pt when cold |
I AM NOT SURE WHAT THE UNLOADER VALVE IS.
THANK YOU |
| Back to top |
YT Home
| Tractor Manuals
| Tractor Parts
| Forum Home
