| Author |
Message |
ldj Long Time User
Posted: Thu Sep 27, 2012 7:17 pm Post subject: Electric fuel pump |
I bought an electric fuel pump for a lawnmower. It worked about an hour and quit. I am selling it on ebay, however I don't think anyone will want it. Below is link to the listing so you can read it and decide if you want one like it from that seller.
http://www.ebay.com/itm/280980577782?ssPageName=STRK:MESELX:IT&_trksid=p3984.m1555.l2649 |
| Back to top |
jammison Regular
Posted: Thu Sep 27, 2012 7:20 pm Post subject: Re: Electric fuel pump |
| ldj wrote: | (quoted from post at 04:17:14 09/28/12) I bought an electric fuel pump for a lawnmower. It worked about an hour and quit. I am selling it on ebay, however I don't think anyone will want it. Below is link to the listing so you can read it and decide if you want one like it from that seller.
http://www.ebay.com/itm/280980577782?ssPageName=STRK:MESELX:IT&_trksid=p3984.m1555.l2649 | What?!!!!!!!! Youm think there are 2 suckers in the world?  |
| Back to top |
rusted nuts Tractor Guru
Posted: Fri Sep 28, 2012 12:50 am Post subject: Re: Electric fuel pump |
Why don"t you just take the thing back to where you got it? Only way they are going to stop building this crap is for us to return it. |
| Back to top |
MarkB_MI Tractor Guru
Posted: Fri Sep 28, 2012 1:10 am Post subject: Re: Electric fuel pump |
A similar Facet fuel pump will set you back at least 50 bucks. That Herko cost you $15.
Facet fuel pumps on eBay
| Back to top |
timcasbolt Regular
Posted: Fri Sep 28, 2012 3:31 am Post subject: Re: Electric fuel pump |
Pardon my ignorance, but what difference does it make if it's on a lawn mower or some other application? |
| Back to top |
bill mart Tractor Expert
Posted: Fri Sep 28, 2012 4:59 am Post subject: Re: Electric fuel pump |
voltage? |
| Back to top |
el6147 Regular
Posted: Fri Sep 28, 2012 5:34 am Post subject: Re: Electric fuel pump |
any one else notice what retailer of automotive equipment was advertising on the the same ebay page , one of the largest retailers of china manufactured equipment in the US! "making it affordable for everyone to have a auto lift at home for oil changes on there american UAW built truck" |
| Back to top |
JeremyR Regular
Posted: Sat Sep 29, 2012 5:10 am Post subject: Re: Electric fuel pump |
Have you checked your voltage coming to to the pump checked for a blown fuse. What kind of mower are you using it on. |
| Back to top |
Billy Shafer Tractor Expert
Posted: Sat Sep 29, 2012 6:26 am Post subject: Re: Electric fuel pump |
All depends on voltage and fuel pressure output. On most small engines. Anything over 4 PSI will open the needle valve and cause flooding. |
| Back to top |
ldj Long Time User
Posted: Sat Sep 29, 2012 2:12 pm Post subject: Re: Electric fuel pump |
Yes I checked all that before saying pump was bad. I bought another pump and it works good---so far. It is on a Kohler M20 on a snapper zero turn. |
| Back to top |
barnE Long Time User
Posted: Sat Sep 29, 2012 5:18 pm Post subject: Re: Electric fuel pump |
Do not tie pump wiring into ignition coil. If ign ition has a ballast resistor in use, pump will be starving for current. Also probably not work at all or correctly. How do I know. Experience long time ago with Renault Dauphine car. Found out after rebuilding motor. This faulty hook up was the only problem. Never made that mistake again after 1966. Dave |
| Back to top |
