4 barrel updraft carb?
biggear
PostPosted: Fri Sep 28, 2012 5:58 am    Post subject: 4 barrel updraft carb? Reply to specific post Reply with quote
Anyone running the zenith 4 barrel updraft carbs?...I have one I wanna put on a Moline 800....just looking for input...what rims ca ya get out of them?..enough fuel?...is a an r9 Stromberg better?....thanks
stumptown63
PostPosted: Fri Sep 28, 2012 8:45 pm    Post subject: Re: 4 barrel updraft carb? Reply to specific post Reply with quote
Not to steal the post but i am workin on an 800 project as well. Is a stromberg na7 enough? or Is an na9 a better choice?
Carb Guy
PostPosted: Sun Sep 30, 2012 4:24 am    Post subject: Re: 4 barrel updraft carb? Reply to specific post Reply with quote
In my opinion, the four barrel does a much better job of atomizing the fuel, but the NAR-9b flows a lot more air.
As for the 800 build below, you would need to disclose what RPM range before a carb could be chosen.
Good Luck!
stumptown63
PostPosted: Mon Oct 01, 2012 7:47 am    Post subject: Re: 4 barrel updraft carb? Reply to specific post Reply with quote
Max rpm of 3000, prob 2000-2500 normally. I have a na7 and a na9 to choose from.
Carb Guy
PostPosted: Wed Oct 03, 2012 6:01 pm    Post subject: Re: 4 barrel updraft carb? Reply to specific post Reply with quote
My best guess would be a 7. Low rpm. If the carb or manifold frosts over go to the bigger 9.
NaturalPuller25
PostPosted: Thu Nov 08, 2012 7:42 am    Post subject: Re: 4 barrel updraft carb? Reply to specific post Reply with quote
We have an updraft 4 barrel zenith on our 800ci Moline. We like it very well. We tried a Stromberg 9 and couldnt get it dialed in as well as the zenith. The zenith runs smooth and we turn 4,000 at 18MPH track speed on gas.
wi50
PostPosted: Thu Nov 08, 2012 12:05 pm    Post subject: Re: 4 barrel updraft carb? Reply to specific post Reply with quote
I assume it has to be updraft, if it's legal for you an upside down Holley with modified metering block and float bowls will be better than anything else.
The Predators work also.
I'd bet that big Zenith is worth more than the cost of a Holley and the work to make it updraft if you can use it.
Post new topic    Yesterday's Tractors Forum Index -> Tractor Pulling All times are GMT - 8 Hours
