m with 301
RSoltwedel
PostPosted: Fri Sep 28, 2012 7:52 am    Post subject: m with 301 Reply to specific post Reply with quote
Got a M with a 301 combine motor in it. The motor runs great but put it on the dyno the other day and it only made 60hp was wondering why and anybody have any answers.
johninmn
PostPosted: Fri Sep 28, 2012 9:32 am    Post subject: Re: m with 301 Reply to specific post Reply with quote
Need more info really. Was it running good or smoking black and missing? Alot of blow by or none? Stock setup? More info needed. Post a pic while your at that sounds like a cool tractor.
RSoltwedel
PostPosted: Fri Sep 28, 2012 9:57 am    Post subject: Re: m with 301 Reply to specific post Reply with quote
It did run good. It had no blow by. And it is just a stock 301 combine motor as far as we know.
RSoltwedel
PostPosted: Fri Sep 28, 2012 10:01 am    Post subject: Re: m with 301 Reply to specific post Reply with quote
It not the best looking but we just got it.
RSoltwedel
PostPosted: Fri Sep 28, 2012 10:11 am    Post subject: Re: m with 301 Reply to specific post Reply with quote
It will not allow me to post a pic because I not a register guest. sorry
DonnieT
PostPosted: Fri Sep 28, 2012 10:35 am    Post subject: Re: m with 301 Reply to specific post Reply with quote
Did you get the tractor from a guy in Lynn IN? I seen it on eBay. Im from that area.
north puller
PostPosted: Fri Sep 28, 2012 11:11 am    Post subject: Re: m with 301 Reply to specific post Reply with quote
Was that at rated PTO speed? I could be wrong, but at 1450 RPM (M pto speed) a 301 may only make 60 hp. What's rated engine speed for a 301, about 2400?
RSoltwedel
Yes we did. was it a bad pickup. Do you know any mor about it.
RSoltwedel
PostPosted: Fri Sep 28, 2012 11:14 am    Post subject: Re: m with 301 Reply to specific post Reply with quote
yes it was. yes a 301 was rated at 2400.
450 Farmall Hooker
PostPosted: Fri Sep 28, 2012 2:29 pm    Post subject: Re: m with 301 Reply to specific post Reply with quote
To see 2400 on the engine, you need to turn the pto shaft on the m at about 890 rpm. Use the 1000 scale and a slide rule on an M&W dyno to figure your hp. I bet you like the new number better.
Post new topic    Yesterday's Tractors Forum Index -> Tractor Pulling All times are GMT - 8 Hours
