Tractor
 Parts
Yesterday's Tractors
Tractor Manuals
Shop for Parts:
Project Journal
Tractor Town
Show & Pull Guide
Related Sites
The Tractor Shed
TractorLinks.com
Ford N-Series Club
Garden Tractors
Today's Tractors
Classic Trucks
Kountry Life
subscribe
unsubscribe
Content Guide
Picture List - TOC
Ad Archives - TOC
Manuals - TOC
CA axle
Post new topic    Yesterday's Tractors Forum Index -> Allis Chalmers
Roger Snider
PostPosted: Fri Sep 28, 2012 12:22 pm    Post subject: CA axle Reply to specific post Reply with quote
How do I remove the axle shaft on a CA. I have the housins off but how do I get the axle out of the brake drum.
Dick L
PostPosted: Fri Sep 28, 2012 12:39 pm    Post subject: Re: CA axle Reply to specific post Reply with quote
The way I do it.
Roger Snider
PostPosted: Fri Sep 28, 2012 12:52 pm    Post subject: Re: CA axle Reply to specific post Reply with quote
Just press it out there is no lock ring or set screw or anything?
Ted in NE-OH
PostPosted: Fri Sep 28, 2012 1:25 pm    Post subject: Re: CA axle Reply to specific post Reply with quote
Yes, there is a set screw in the brake drum on the left side remove that first.
steve(ill)
PostPosted: Fri Sep 28, 2012 6:43 pm    Post subject: Re: CA axle Reply to specific post Reply with quote
scrape all the crud off the shaft down to the brake drum. wire brush it the best you can. Turn the shaft untill you can see a square head set screw thru the 1 inch hole in the housing, remove the set screw. Remove the bearing cap 4 bolts and plate on the outside of the shaft. Setup in the press, block it square and push the shaft out thru the drum and out the other side with the bearing. Helps to spray penetrant on the shaft and hub. You can do it with a 5 pound hammer and a brass plate, but sometimes it takes 200 swings to get it to move.
