| Author |
Message |
win2ktek Guest
Posted: Sat Sep 29, 2012 6:53 am Post subject: JD 301AG PTO won't spin under load |
I am a new owner of a 197? JD 301AG. It is the 8 speed transmission with park(no reverser). I found an issue with the PTO. It engages and spins with no load on it, but if I hook up my 6ft finish mower it won't spin. Can anyone point me in the right direction. I've only had 50s fergusons previously. It also has a pull knob between the shifters. What is the function of that? |
| Back to top |
Tx Jim Tractor Guru
Joined: 14 Feb 1999 Posts: 13151 Location: Coyote Flats,Tx
Posted: Sat Sep 29, 2012 8:48 am Post subject: Re: JD 301AG PTO won't spin under load |
Remove the sheet metal cover that gear shift levers protrude through and there should be a port to test pto clutch. PSI when engaged should be 165 psi. If pressure is low you could possibly have a cracked or leaking supply tube or leaking clutch seal. Don't continue trying to operate it until problem is corrected.
| Back to top |
buickanddeere Tractor Guru
Joined: 31 May 2003 Posts: 23627 Location: in front of computer
Posted: Sat Sep 29, 2012 9:50 am Post subject: Re: JD 301AG PTO won't spin under load |
A dire need of an operator's manual. There are numerous functions and service items that are not obvious. A few lines on the Internet does not compare to a dozens and dozens of illustrations, specs and service items in the real JD OM. Don't waste your time and $ on an IT manual either.
The nice folks at 1-800-522-7448 will assist you. |
| Back to top |
Tx Jim Tractor Guru
Posted: Sat Sep 29, 2012 10:47 am Post subject: Re: JD 301AG PTO won't spin under load |
In this instance the operators manual would only help to wedge the garage door open but not list diagnoses or repair. |
| Back to top |
Posted: Sat Sep 29, 2012 11:28 am Post subject: Re: JD 301AG PTO won't spin under load |
The OM to ID the controls such as the mystery lever between
the shifters.
It goes without saying that a service manual for diagnosis
assistance is required. |
| Back to top |
win2ktek Guest
Posted: Sat Sep 29, 2012 12:57 pm Post subject: Re: JD 301AG PTO won't spin under load |
So it sounds like the PTO uses hydraulics and isn't a 2 stage clutch type? |
| Back to top |
Tx Jim Tractor Guru
Posted: Sat Sep 29, 2012 1:52 pm Post subject: Re: JD 301AG PTO won't spin under load |
Yes if there's a control handle between the 2 gear shift levers then your tractor has a hyd operated pto. |
| Back to top |
win2ktek Guest
Posted: Sun Sep 30, 2012 3:19 am Post subject: Re: JD 301AG PTO won't spin under load |
Does engaging the PTO require shifting the PTO lever on the left side in gear and pulling up the center knob between the shifters? If so I haven't tried that yet. |
| Back to top |
Tx Jim Tractor Guru
Posted: Sun Sep 30, 2012 7:08 am Post subject: Re: JD 301AG PTO won't spin under load |
| win2ktek wrote: | | (quoted from post at 07:19:44 09/30/12) Does engaging the PTO require shifting the PTO lever on the left side in gear and pulling up the center knob between the shifters? If so I haven't tried that yet. |
Yes one must move the lever by left heel when sitting in seat for hyd pto to operate when pto clutch is engaged. |
| Back to top |
win2ktek Guest
Posted: Sun Sep 30, 2012 8:49 am Post subject: Re: JD 301AG PTO won't spin under load |
Thank you for the assistance. Only having old fergusons before I didn't know you have to engage the PTO lever on the left side and pull the center knob up. The PTO now spins the mower.  |
| Back to top |
Tx Jim Tractor Guru
Posted: Sun Sep 30, 2012 9:24 am Post subject: Re: JD 301AG PTO won't spin under load |
Congratulations. |
| Back to top |
